MUM Europe 2020
SniperWolf
is it possible to control the bandwidth of a specific site??
Mon Jan 16, 2006 1:21 am
Hi
I want to reduce the bandwidth on a specific site... as example... I have a lot no. of the clients download songs. and they took a larg part of the bandwidth though.
Is there a way to reduce the badwidth of site??
JJCinAZ
Mon Jan 16, 2006 11:20 am
Queues. Use mangle rules and Address Lists to mark the packets to the sites in question. Then add a queue which limits throughput based on that packet mark.
SniperWolf
Mon Jan 16, 2006 9:28 pm
umm... well.. I wanna bother u a bit... just a simple example if u can give... the idea isn't so clear how to combine managle and queues
djape
Mon Jan 16, 2006 11:02 pm
Hm...I don't see need for mangle here. You can just do simple queue and place it on top of other queues
go to queue simple and type this:
add name="site" target-addresses=0.0.0.0/0 dst-address=x.x.x.x/32 (site IP)interface=all parent=none priority=8 queue=default/default limit-at=0/0 max-limit=64000/64000 (or whatever) total-queue=default
And this should limit all traffic to specific site to 64k
Remeber, this queue should be placed on top of other queues.
Cheers....
I drink like a pirate and smoke like a hippie...
JJCinAZ
Tue Jan 17, 2006 12:00 am
Yes, djape is correct, but I suggested the mangle so that address lists could be used to manage the list of site, else you will end up with lots and lots of queues.
Take a look at Butch Evans site http://www.butchevans.com/articles.php?cat_id=3
for some help as well.
djape
Tue Jan 17, 2006 1:49 pm
Completely agree...
For few sites queue simple is cool, but for whole bunch of sites you should lesten to JJCinAZ
Cheers..
SniperWolf
Tue Jan 17, 2006 11:09 pm
and i am thankful for both of u....
Users browsing this forum: Buster2, jmdg11 and 116 guests
