reiser4
Very high cpu usage with 20+ sstp clients
Wed Aug 01, 2012 5:39 pm
Hello, I am running some mikrotik routers with sstp server. I have two different situations, both with about 20-30 sstp clients (mikrotik 751); I get in both routers 100% cpu usage; this is not really a problem because it is responsive and gives good speed in sstp tunnels.
what do you need to debug this properly? I am not using an encryption-enabled profile.
edit: host is rb1100ah, I have also tried with x86 and inside metarouter, I get the same results.
hassibi
Trainer
Trainer
Re: Very high cpu usage with 20+ sstp clients
Tue Aug 07, 2012 3:14 am
Hello
what version of routeros you use?
syadnom
Tue Aug 07, 2012 3:38 am
Same here, 30 sstp gives 50% CPU on rb1200. That's a lot of overhead. 5.12 currently and average throughput on all tunnels is well under 1Mb
roadracer96
Forum Veteran
Forum Veteran
Tue Aug 07, 2012 3:57 pm
What is the total encrypted traffic you are pushing? RB1000 with 200ish clients and about 40-50mbit of traffic pushes 25-30% cpu. I can see an RB1200 sweating with 1/2 that traffic.
Disassembler
Fri Aug 10, 2012 7:06 pm
Same problem here,
RB433, ROS 5.19, ~60 SSTP connections and constant 100% CPU usage. ROS responds quite well and almost no disconnecting was reported, though.
Clients are pushing about 500 bytes each 5 seconds, so there's almost no traffic. With 5.12 from which I updated, CPU usage was around 15%.
reiser4
Thu Aug 16, 2012 3:57 pm
I am using 5.19
any change about sstp in 5.20? I'd rather not upgrade a production router without a good reason.
kazak
Sun Sep 02, 2012 2:49 pm
Unfortunatelly have same problem with 5.20 - 100% cpu load mostly caused from ppp when sstp server active.
After restart sstp server it is ok until next sstp login.
Regards,
Dimitar Kazakov
Campano
Fri Sep 07, 2012 4:14 pm
y use this simple script:
/interface sstp-server server set enabled=no
:delay 5
/interface sstp-server server set enabled=yes
and set in scheduler with 1 hour period
poor solution, but works
jetboy
Fri Sep 21, 2012 7:48 pm
I am having a similar issue with way less clients. 10 users total and maybe 3-4 sstp. RouterOS 5.20. RB2011.
net365
Sat Sep 22, 2012 1:34 pm
I have the exact same issue on a RB1100AH with 6/7 clients. ROS 5.19 AND ROS 5.20
MT confirm its a bug and will be fixed next release. Can you get away with using L2TP/PPTP? We have to use SSTP because one of our cable providers blocks the other 2!
Best of luck
Jon
reiser4
Sat Sep 22, 2012 1:40 pm
I tried also pptp but sstp is like skype: it works everytime, with static or dynamic ip and behind any kind of nat and firewall.
mrz
Mon Sep 24, 2012 12:15 pm
High CPU usage caused by SSTP will be fixed in v5.21
reiser4
Mon Sep 24, 2012 1:24 pm
5.21 release date?
brainy
Mon Sep 24, 2012 1:57 pm
"when it's done"? :P
Campano
Mon Oct 15, 2012 6:02 pm
And any news from anyone? it's really fixed in 5.21 version?
syadnom
Tue Oct 16, 2012 2:28 am
Bump, is this fixed in 5.21? The changelog mentions sstp but isn't clear on it fixing this issue
janisk
Tue Oct 16, 2012 8:37 am
it should be fixed. At least testing routers did not show this behaviour again. So please check this locally.
jetboy
Thu Jan 03, 2013 3:26 pm
5.21 fixed this for me. I have since upgraded to 5.22 and have not seen this issue with it either.
Users browsing this forum: Baidu [Spider], Bing [Bot], jakir69 and 111 guests
