masc
email not working in 5.19
Sun Aug 05, 2012 10:35 pm
We been trying to sen a email in routeros 5.19 and is not working, when we send from a 4.11 os version it´s ok, sents the email ok
psamsig
Re: email not working in 5.19
Mon Aug 06, 2012 1:23 am
Works fine for me. You did notice that parameters changed a bit between 4.11 and 5.19 right?
masc
Mon Aug 06, 2012 3:15 am
This is what we are doing:
/tool
/e-mail
send to="user@domain.com" from="<user1>" body="test0" subject="test0" server="x.x.x.x" password="xxxxx" user="me@mydomain.com" port="25"
and in 4.11 works fine, not with the same parameters
but in 5.19 we get error connecting to server
if we ping the server, it pings ok, its in the same subnet
Thank´s
psamsig
Mon Aug 06, 2012 12:41 pm
I have had my fair share of e-mail problems, but it always comes down to misconfiguration (firewall in either end, spamfilter frontend and so on), never RouterOS. And as mentioned already, I have 5.19 sending mails like a charm.
SurferTim
Mon Aug 06, 2012 1:31 pm
If you want to check what is happening, then enable verbose email logging.
/system logging
add topics=e-mail,debug action=memory
Try another email send, then check the log.
masc
Tue Aug 07, 2012 1:13 am
Nothing just:
Error sending E-mail <subject>: error connecting to server
but we can ping the server, even telnet the email server
Thank´s
normis
Tue Aug 07, 2012 10:17 am
maybe server requires authentication, or uses another port ?
masc
Tue Aug 07, 2012 9:56 pm
We tried also with gmail
tls activated, port 587
and we get the same error
We are doing this in a 450g
and in a 411 with 4.11 that is in the same subnet we can get it working
Thank´s
biomesh
Tue Aug 07, 2012 11:19 pm
/tool e-mail
set address=173.194.77.108 from=mikrotik@mydomain.net password=emailpwd port=587 starttls=yes user=user@gmail.com
/tool e-mail send to="user@gmail.com" body="Router email" subject="$[/system identity get name] $[/system clock get time] $[/system clock get date] Alert" from="mikrotik@mydomain.net" server="$[:resolve "smtp.gmail.com"]" tls=yes
This works for me (you need to update the email addresses and password, of course)
masc
Wed Aug 08, 2012 1:16 am
Solved!
different port
Thanks to anyone
tnakir
Wed Jan 08, 2014 4:08 pm
I'm having other e-mail issues with 6.7
I'm sending email with this:
/tool e-mail> send from=mail@mail.com to=mail2@mail2-com server=x.x.x.x port=25 user=someuser password=somepwd subject="Message subject"
body="Message"
and the command does not send subject or the body (check the attachment). Any ideas?
Users browsing this forum: Google [Bot], klaus007, stralis, ZacharyBeade and 153 guests
