Fumi
Hotspot login by https
Wed Aug 08, 2012 1:29 pm
Hi Mikrotik people,
when I try to access to login page by mail.google.com (HTTPS) explorer don't redirect me to login page! But If I try with normal page HTTP the explorer redirect me to login page of hotspot, then I login and I can access to mail.google.com HTTPS.
How I can make to access first time to mail.google.com??
hassibi
Trainer
Trainer
Re: Hotspot login by https
Wed Aug 08, 2012 5:18 pm
Hello
you want to your users can access https://mail.google.com without any authentication first time?
Fumi
Wed Aug 08, 2012 9:00 pm
When my users before login to hotspot they connect to www.google.com and the login page apear.. but when they put https page like mail.google.com the login page not appear.
Feklar
Wed Aug 08, 2012 11:37 pm
That is because you cannot redirect an HTTPS session to a HTTP session. They are different protocols and use different ports. This is the same for every gateway/hotspot out there.
Since we don't use HTTPS on our initial login pages, I'm not sure if you run an HTTPS version of your login page if you will or won't be able to redirect HTTPS users to that.
anass
Wed Aug 29, 2012 5:51 pm
have you resolved this problem
blingblouw
Thu Aug 30, 2012 9:25 am
Yes, you have to use https on the initail login page. Then the problem becomes that a user will always get a certificate warning.
If you look at the warning it will make sense. Download a demo certfiicate from thawte and test it. It makes sense
Fumi
Wed Sep 05, 2012 1:48 pm
It work for me! Thans for all!
injuredx
Thu Sep 06, 2012 8:31 am
i'm facing the same problem... please help me how to fix it? step by step please... :)
Users browsing this forum: No registered users and 95 guests
