maximo401
How to limit number of concurrent connections in Mikrotik
Wed Aug 08, 2012 2:42 pm
Good day to all!
We would like to provide free 1 hr Internet access to customers but we would like to limit concurrent connections on Mikrotik to say 100 (active connections) only. Then after 1 hour use, if active connections is less than 100, he should be able to use the Internet again say after 5 minutes. Is there a way to control or do this in Mikrotik? I am thinking of using the Free Trial feature but how can we control concurrent connections?
Please help. Thanks
Ivoshiee
Re: How to limit number of concurrent connections in Mikroti
Wed Aug 08, 2012 3:06 pm
I haven't seen that kind of functionality within ROS. It should be there, but I am afraid it is not.
Maybe it will get implemented under connection tracking?
http://wiki.mikrotik.com/wiki/Manual:IP ... n_tracking
maximo401
Wed Aug 08, 2012 3:34 pm
Hi Ivoshiee, thank you for your prompt input.
I tried to look at the Connection Tracking feature but couldn't see a possible way to count and control concurrent connections. A single user can have multiple connections depends on his activity.
Looking around, it came to my mind of using the DHCP scope. Say limit the IP available to 100 and expiration is 1 hour only. But the concern that I am thinking that would come up is that, since it will be a /25, there will be some spare IP from the scope (since we only need 100) that users may guess and set statically? How should or how can we address it?
Ivoshiee
Wed Aug 08, 2012 4:02 pm
I am afraid the DHCP is not the right place to make it. Hopefully some ROS guru will step in and enlighten us hot to properly implement that.
maximo401
Wed Aug 08, 2012 4:21 pm
Thank you again, Ivoshiee
Let us see what the Forum Gurus would recommend.
greencomputing
Wed Aug 08, 2012 5:09 pm
Hi sir
To limit the number of concurrent sessions, you can do it using the property connection-limit under /ip firewall filter. Using an example found on this forum (and on the wiki) :
max 100 connection for every host ip (32 bit of netmask) :
/ip firewall
add chain=forward protocol=tcp tcp-flags=syn connection-limit=100,32 action=drop comment="connection limit" disabled=no
in this case , max 100 connection for every host ip (32 bit of netmask).
Historically , for UDP case, it was a suffering pain but after RoS 5.7-5.8 you can finally use this useful property connection-limit to limit both udp and tcp case.
Hoping this will drive you in the right direction to implement your control.
have a nice day
If answer was helpful to you why to not plan to... give me karma :)
greencomputing
MTCNA / MTCRE certified Senior Mikrotik Consultant
maximo401
Wed Aug 08, 2012 7:38 pm
Dear Mr. greencomputing,
Thank you very much for your input. I will test this on a workbench starting with a 2 users maximum and will an update here. Thanks again.
Users browsing this forum: Google [Bot] and 139 guests
