lav21
tools - profile - firewall cpu 30%, but ALL rules OFF...wtf?
Fri Aug 10, 2012 8:20 pm
tools - profile - firewall - cpu 30-40%, but ALL firewall rules OFF (filter, nat. mangle - 0 rules).
what is a mystery ?
hassibi
Trainer
Trainer
Re: tools - profile - firewall cpu 30%, but ALL rules OFF...
Sun Aug 12, 2012 6:46 pm
Hello
I think its Connection Tracking...Disable it and check your router profile again.
Good luck.
Ivoshiee
Sun Aug 12, 2012 6:53 pm
Hello
Good luck.
What good does disabling of the connection tracking will do? Why should I need it anyway?
lav21
Sun Aug 12, 2012 8:47 pm
Features affected by connection tracking
NAT
firewall:
connection-bytes
connection-mark
connection-type
connection-state
connection-limit
connection-rate
layer7-protocol
p2p
new-connection-mark
tarpit
p2p matching in simple queues
http://wiki.mikrotik.com/wiki/Manual:IP ... n_tracking
lav21
Sun Aug 12, 2012 9:39 pm
hassibi, Thank you!!!!!!!
(Огромное спасибо)
Exactly!!!!
Conntrack disabled and cpu load go down.
Although none of these features have not been used:
NAT
firewall:
connection-bytes
connection-mark
connection-type
connection-state
connection-limit
connection-rate
layer7-protocol
p2p
new-connection-mark
tarpit
And conntrack table is not full
Why?
hassibi
Trainer
Trainer
Mon Aug 13, 2012 9:15 am
Because by default RouterOS check connection and its state.
its recommended that disable connection tracking if not use that feature...
Good Luck
NAT
firewall:
connection-bytes
connection-mark
connection-type
connection-state
connection-limit
connection-rate
layer7-protocol
p2p
new-connection-mark
tarpit
lav21
Mon Aug 13, 2012 9:31 am
but, what could be the reason for this behavior?
I still need to use DNAT.
I remind you - a few more similar servers with enable conntrack, but do not have this problem.
An interesting mechanism of the phenomenon .....
lav21
Tue Aug 14, 2012 3:56 pm
no idea?
help......................................
Users browsing this forum: No registered users and 84 guests
