nissandata
[Feature Request] Adress list as member of Adress list
Thu Aug 16, 2012 1:48 pm
Hi!
is this the right place to ask for features?
I use the adress list of the firewall alot, usually to be able to easily change subnet in the future, move router from lab to production, add allowed subnets/ips to do stuff. Or to import tamplate configurations to new devices, it's easier to get it right if you just change your adresslist after the import to match the application than to go edit all the firewall rules.
It would be very convinient to be able to add an adresslist to an adresslist, much like you can make a group a member of another group in a Windows Domain.
From a administrational point of view it would be very convinient.
Now the same IP's have to be present in several different adresslists, depending on what they should be able to do, wich make it easier to make an error and more to edit.
nissandata
Re: [Feature Request] Adress list as member of Adress list
Sat Dec 29, 2012 2:13 pm
Still thinks this would be a very convenient and good feature, and my guess is that it might be easy to add in a big new version of rbOS. So doing a bumpie even though it's against good forum code of conduct
andreacoppini
Trainer
Trainer
Sun Dec 30, 2012 11:43 am
+1.
Firewall objectification would make MT a great competitor to the big boys.
- No strings attached -
<< Please give good Karma if this post helped you. Press the + button above the Location entry
TrollMan
Sun Dec 30, 2012 1:35 pm
+1
Users browsing this forum: Bing [Bot], xormac and 207 guests
