MUM Europe 2020
pca
Public block IP routing with pppoe
Thu Aug 23, 2012 7:06 am
Hello
I was wondering if someone would be able to assist in teaching me how to configure my RB493G for the following
ADSL modem in bridge mode
RouterBOARD 493G creates the pppoe link to ISP
ISP has allocated me a /29 block of addresses
How do I correctly route my allocated block, which is a different subnet to the public facing pppoe IP address through to my LAN ports?
Lets assume I have eth4, 5, 6 and 7 tied together for me LAN segment.
I'd really appreciate any help as I am only new to routing.
Thanks in advance
vk7zms
Re: Public block IP routing with pppoe
Sun Aug 26, 2012 8:55 am
are you planning to use real world ip addresses directly on any other hosts in your network, or do you intend to setup a series of src-nat/dst-nat rules for specific ports to specific hosts etc?
pca
Tue Sep 04, 2012 1:57 am
Hi vk7zms
I am planning to use real world IP's. I have a block of /29.
I am not sure how to configure the RB493G with PPPoE and static IP, plus routed block of /29 onto a group of switched ports.
Obviously, I have the PPPoe link working however have no idea how to configure the routed block to work on the LAN side. My goal is to assign computers connected to the group of switched ports with the routed block.
Thank you for your time.
Regards
James
vk7zms
Tue Sep 04, 2012 12:31 pm
You don't really have to do anything to "route" the real world block as MT does it by default.
Just add the first of your real world block to whichever Ethernet port you are using for the switch master, and use this address as the default gateway for the hosts you have plugged into the switched ports.
pca
Thu Sep 06, 2012 1:54 am
Thanks for your assistance vk7zms.
I will give this a try within the next few days.
Thanks again.
Zebble
Thu Sep 06, 2012 6:00 am
Yup, definitely works as suggested. We have a PPPoE connection with a static ip, as well as a /28 and /29. We've assigned the first address of each subnet to a physical port on an RB1200, and made the ports standalone (ie. master ports with no slaves) and works great! Definitely nice to have completely separate and secured subnets.
Users browsing this forum: Google [Bot], jmraemer, Kindis, MSN [Bot] and 134 guests
