azurtem
Trainer
Trainer
wifi card 'disabled port'
Thu Aug 30, 2012 2:55 pm
Hi
I'm running a brand new RB433uahl 5.20 equipped with wifi card :Sparklan mPCI WMIA 198
wlan1 and eth2 are bridged together
From time to time I notice that the wlan1 interface appears in italics and
when I look at the ports tab of Bridge, the port is indicated as "disabled port"
instead of the usual "designated port"
Is this by design, can't I hace the wifi card 'always' on ?
thanks
yann
SurferTim
Re: wifi card 'disabled port'
Thu Aug 30, 2012 3:58 pm
Try this:
/interface wireless
set X disable-running-check=yes
azurtem
Trainer
Trainer
Mon Dec 03, 2012 5:02 pm
Thanks SurferTim (sorry about the delay in my response)
Users browsing this forum: Bing [Bot], i4jordan, McSee and 66 guests
