David1234
need to block websites
Mon Sep 03, 2012 1:32 pm
Hello
I want to control the traffic and block websites
I'm reading the manual at - http://wiki.mikrotik.com/wiki/How_to_Bl ... sing_Proxy
can I do the blocking without configure proxy ?
or do I have to it in order to make it work?
and 1 more thing -
I want to make the html of the error to be the standard html+ IMG of my choice that will use as a button to redirect to my site
so let say you want to enter http://www.notallow.com
you will get:
ERROR: Forbidden
[IMG]
cant enter the website! http://www.notallow.com/:
•Access Denied
and if you press the IMG you will redirect to google.com
I have create transparent hotspot (like it say in this post - http://forum.mikrotik.com/viewtopic.php?f=2&t=34336)
and this is my error.html file
the LAN is 10.0.0.1
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html><head><meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<title>ERROR: $(status)</title></head>
<body><h2>ERROR: $(status)</h2>
<hr noshade size="1px"/>
$(if error)
<p>cant enter the website! <a href="$(url)">$(url)</a>:</p>
<ul><li><strong>$(error)</strong></li></ul>
$(endif)
</body>
<img src="http://10.0.0.1/no.png">
</html>
Thanks ,
MikroTikIQ
Trainer
Trainer
Re: need to block websites
Wed Sep 05, 2012 12:19 am
Hi...
First I would like to ask you do have single website you want to block or you have list.?
there is a way to use firewall/filter and control accessing web site..
And when client try to access that web site will redirect to you external web page..
Waiting your reply to c how we can start..
Best regards
Ali Sami
David1234
Wed Sep 05, 2012 12:51 pm
I want to block several site
lets make an example - www.yahoo.com , www.gmail.com , www.cnn.com
Now I want\need every time someone try to enter this sites
he will get the error.html (from the proxy) that will tell him that the site is forbidden, and an img that when he will press it he will return to www.mywebsite.com
hope it's understood
Thanks ,
MikroTikIQ
Trainer
Trainer
Fri Sep 07, 2012 1:03 am
Dear..
the easiest way is you can use DNS..
add static dns record for this web sites.. and make them resolve you server ip address instead of real one..
Also you need to force you mentioned client to user only router dns..
/ip firewally add chain=dst-nat src-address=(you client ip range) protocol=udp dst-port=53 action=redirect to-port=53
test it and let me know..
if you want to know how to add static dns just :
/ ip dns static add name=www.google.com address=(yourServerIP)
Best regards
Ali.
AngelaS
Sun Sep 09, 2012 12:43 pm
When it comes to blocking websites I like to use an application called Qustodio (http://www.qustodio.com/ ). It's really easy to configure and free.
David1234
Wed Sep 12, 2012 3:16 pm
what does Qustodio help me?
If I have Wifi routers - where do I install the program?
Users browsing this forum: Google [Bot], Kindis, td32, TimurA, Zacharias and 95 guests
