kazim
bgp configuration between minkrotik and cisco router
Wed Sep 12, 2012 1:47 pm
Hello!
I working in an ISP and using Mikrotik.I have 40 customers which connected with private IP's (nating in mikrotik).Now i want to connect these client with public ip.My customers are demanding for some public ip pools like 29/, /28,/27 and so on.
I have got 180.94.83.16/28 for another ISP.They are using cisco router.
Now I buy a pool of public IP's from APNIC which are (103.15.238.0/23) and my AS Number is (AS58697) and the Remote (AS58330)(180.94.83.17 is the IP of remote side.
Now i want to configure BGP on my mikrotik server to provide public IP's to my customers.
My gateway is 180.94.83.17/28 and my mikrotik ip is 180.94.83.18/28
any can send the me the configuration. I shall be very thankful for this act of kindness
mrz
Re: bgp configuration between minkrotik and cisco router
Fri Sep 14, 2012 3:48 pm
It is a simple BGP peering, look at this example,
http://wiki.mikrotik.com/wiki/Manual:Si ... ultihoming
Only difference is that it has two peers, you need only one.
kazim
Sat Sep 15, 2012 5:51 am
Thanks a lot for your kind reply
i will make one peer configuration if there is any issue i will inform you.
thanks again
Muhammad kazim
Users browsing this forum: inteq and 131 guests
