I am new to MikrotTik ...
Now we want to replace old Linksys with MikroTik (RB2011L V5.2) in office.
i make same basic steps to make it worked
- 1. Setup ip address and dhcp sever to lan
2. disconnect Linksys wan from cables modem and connect MikroTik
3. setup DHCP-Client (on the interface that connected to cable modem)
4. setup L2TP client on the router to connect my ISP.
5. add static public IP address from ISP to ip address on interface VPN (to ISP)
6. setup NAT
- 1. when we try to send ping via router to outside we got time out . i tried to run traceroute on the router we i sow that the router tried to go out side to cable modem
2. we also tried to install VPN server on the router without successful (we thinks that its also related to the first issue)
we allowed L2TP and PPTP Server , create interface of both and we tried to connected from outside we got error 678 the remote computer did not respond but when the laptop connected inside its works.
Thanks in advance!
