Ehman
RB751G-2HnD config file restore nightmare!
Sun Sep 16, 2012 4:38 am
Hi folks
I've got a huge! problem, I made a nice config file and want to restore the config file on other routerboards, ok here is the results:
I made the config file on this device:
RB751G-2HnD
firmware: v2.41
ROS 5.20
---interfaces list---
ether1
ether2
ether3
ether4
ether5
wlan1
and did a backup, and restored the file on a exact same model with the exact same firmware and ros on it, and it gave me this
ether1
ether2
ether3
ether4
ether5
wlan2 <---disable and configured
Why does it do that?!
I did a reset on both devices and just enable the wlan1 backup and restored it over to the new routerboard with same model, and it also made a wlan2 :shock:
thx
forne
Re: RB751G-2HnD config file restore nightmare!
Sun Sep 16, 2012 10:55 am
Try to use export/import instead of backups.
Ehman
Sun Sep 16, 2012 3:00 pm
Hi, this works better, but the problem here is, it clones the MAC address, I don't want everything to have the same MAC address, and the Backup and Restore is supposed to work 100%, I think its a bug! :?
forne
Sun Sep 16, 2012 3:11 pm
I think backup/restore is intended for using on the same device. Try "/export compact". It won't include MAC addresses (and any other default configuration) to the output.
Ehman
Wed Sep 19, 2012 1:51 am
Hi, This fixed the MAC address issue, but still, its making a empty wlan2 interface :*(
cbrown
Trainer
Trainer
Wed Sep 19, 2012 3:05 am
If you post the /export compact file we could tell you what is happening.
C.Brown
cbrown[at]cbrown.co
Telegram: @chris4brown
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
Ehman
Wed Sep 19, 2012 2:19 pm
For some odd! reason, importing a compact export file onto a new routerboard seems to work 100%, I dont understand why! I might have change a couple of things like identity and small things like that, but it would be great if MK can fix this problem, so that one can be able to backup a file and then restore it onto another device without any hickups, .... mainly for NAS devices like hotspots
cbrown
Trainer
Trainer
Wed Sep 19, 2012 2:22 pm
Backup and restore is only intended for use on the same device. Import/Export is for different devices. It is not a bug.
C.Brown
cbrown[at]cbrown.co
Users browsing this forum: eworm, inversistemas, svmk and 153 guests
