trueskaarj
DHCP option 249
Mon Sep 17, 2012 9:42 am
Hello! Can mikrotik dhcp-client receive routes from ISC-DHCP in option 249? If it possible, how can i configure it?
Thanks.
forne
Re: DHCP option 249
Mon Sep 17, 2012 10:47 am
Try to specify "add-default-route=yes" in dhcp-client. In fact, it adds not only a default route.
trueskaarj
Re: DHCP option 249
Mon Sep 17, 2012 1:02 pm
I has it already specified:
[admin@MikroTik] > ip dhcp-client print detail
0 interface=ether10 add-default-route=yes default-route-distance=2 use-peer-dns=yes use-peer-ntp=yes
DeGlucker
Re: DHCP option 249
Tue Jul 09, 2013 7:28 pm
The same problem ! Theoretically starting from ROS 6.0 DHCP client has ability to get additional options from DHCP server. I need to get ms-classless-routes (Option 249) from my ISP (windows dhcp client successfully got it). How to properly setup dhcp client in mikrotik ? As I understand I should create new dhcp option with code 249, but what I should specify in "Value" field ?
Users browsing this forum: abhsek, Google [Bot], Google Feedfetcher, Nadir16, YaCy [Bot] and 129 guests
