aaronm007
Question on Dual-WAN setup
Mon Sep 17, 2012 7:43 pm
I have a routerboard 1000 running version 5.12. I have quite a bit of experience with mikrotik but this is the first time I’ve tried to use the stateful connection tracking feature. I am trying to setup failover with two internet connections (labeled WAN-DSL and WAN-SC) but with a couple of caveats.
I want to:
1. Use WAN-DSL as primary connection for my LAN (10.0.0.0/24).
2. Failover to WAN-SC upon failure of WAN-DSL.
3. Assign traffic from a specific host (10.0.0.252) to always use WAN-SC.
4. Dst-nat (port-forward) tcp 3389 traffic to an internal host (10.0.0.12) over WAN-DSL.
5. Dst-nat (port-forward) tcp 3389 traffic to same internal host also over WAN-SC.
After going over tutorials and how-tos on the Internet, I have a basic configuration setup. However it does not work yet, and need some input on whether I am approaching this from the correct angle.
Mangle rules:
0    chain=input action=mark-connection new-connection-mark=WAN-DSL-connections passthrough=no in-interface=WAN-DSL
 1   chain=input action=mark-connection new-connection-mark=WAN-SC-connections passthrough=no in-interface=WAN-SC
 2 X chain=prerouting action=mark-connection new-connection-mark=WAN-SC-connections passthrough=no src-address=10.0.0.252 dst-address-type=!local in-interface=LAN
 3   chain=prerouting action=mark-connection new-connection-mark=WAN-DSL-connections passthrough=no dst-address-type=!local in-interface=LAN
 4   chain=output action=mark-routing new-routing-mark=to-WAN-DSL passthrough=no connection-mark=WAN-DSL-connections
 5   chain=output action=mark-routing new-routing-mark=to-WAN-SC passthrough=no connection-mark=WAN-SC-connections
NAT rules:
 0   chain=dstnat action=dst-nat to-addresses=10.0.0.12 protocol=tcp in-interface=WAN-DSL dst-port=3389
 1   chain=dstnat action=dst-nat to-addresses=10.0.0.12 protocol=tcp in-interface=WAN-SC dst-port=3389
 2   chain=srcnat action=masquerade out-interface=WAN-SC connection-mark=WAN-SC-connections
 3   chain=srcnat action=masquerade out-interface=WAN-DSL connection-mark=WAN-DSL-connections
Here is my theory behind this:
1. Use mangle rules to mark any connections coming into each WAN connection (input chain).
2. Mark any connections from 10.0.0.252 with the WAN-SC-connections mark (prerouting chain). This rule is currently disabled. It doesn’t work when I enable it, I think due to the issue I am having with the routing marks.
3. Mark everything else from the LAN with the WAN-DSL-connections mark (prerouting chain).
4. On our output chain set a unique routing mark that corresponds with each of the two connection marks.
5. Set the gateway for each default route based on routing-mark and let each interface masquerade rule NAT the traffic.
I have two default routes with the ping probe enabled (one going to each provider), with the WAN-SC set to a higher distance (for the failover function). However when I try to set each default route to use its respective routing-mark (to-WAN-X), traffic just seems to be dropped and I get no traffic flow. Everything seems to be getting marked properly, but the routing table does not seem to be honoring the routing-marks.
Does anyone have any ideas why this isn’t working properly? Am I approaching this problem with the correct method? Thanks
forne
Re: Question on Dual-WAN setup
Tue Sep 18, 2012 11:56 am
I want to:
This can be easily done without any routing marks. Just make sure you have two default routes in your main routing table pointing to two ISPs with different distances.
Now you should create another routing table (routing-mark=to-WAN-SC) with only the default route pointing to WAN-SC. Don't remove it from the main table hovewer, create a duplicate. Also you should mark outgoing packets from src-address=10.0.0.252 with routing-mark=to-WAN-SC in the prerouting mangle chain. No need to mark connections here.
/ip firewall mangle
add chain=prerouting action=mark-routing new-routing-mark=to-WAN-SC passthrough=no src-address=10.0.0.252
Now you should remember the interface from which each connection was originated, and use connection marks for that. But mark only those connections, that were originated from WAN-SC. Then mark needed outgoing packets with a routing-mark. Do it in the prerouitng mangle chain like this:
/ip firewall mangle
add chain=prerouting action=mark-connection new-connection-mark=WAN-SC-connections passthrough=no in-interface=WAN-SC connection-mark=no-mark
add chain=prerouting action=mark-routing new-routing-mark=to-WAN-SC connection-mark=WAN-SC-connections passthrough=no src-address=10.0.0.12
NAT rules:
Remove connection-marks from NAT rules. Simplified version:
add action=masquerade chain=srcnat out-interface=!LAN
add action=dst-nat chain=dstnat dst-address-type=local in-interface=!LAN dst-port=3389 protocol=tcp to-addresses=10.0.0.12
You misuse the input chain. It's only used for packets going to the router itself. Similarly, the output chain is only used for packets originating from the router itself. For packets going from one interface to another you should use the forward chain.
aaronm007
Tue Sep 18, 2012 10:42 pm
Most excellent. It seems I was trying to over complicate things. Thanks very much for your clear explanation, it seems to be working perfectly.
Thanks again
Users browsing this forum: mbovenka, Sob, zmitya and 112 guests
