MUM Europe 2020
rajco
CPU 100% PPP
Tue Sep 25, 2012 1:14 pm
I have on one location RB1100AH with 100% cpu usage. When check profile I have two PPP with over 60%. I have maximum 10 PPTP connection in the same time and they are authenticated with radius (Active Directory). Where is a problem?
mrz
Re: CPU 100% PPP
Tue Sep 25, 2012 6:13 pm
This should be sstp related. Problem will be fixed in v5.21
rajco
Re: CPU 100% PPP
Tue Sep 25, 2012 6:21 pm
Thank you mrz, disabling sstp fixed problem. I suspect on sstp but I don't know why I didn't tried before your answer to disable.
paranoid
Re: CPU 100% PPP
Fri Sep 28, 2012 10:48 am
hi
here some script which does a workaround
until 5.21 is released
/system script
add name=cpuload policy=ftp,read,write,winbox,api source=":local cpuload [ /system resource get cpu-load ]\r\
\nif ( \$cpuload = 100 ) do {\r\
\n/interface sstp-server server set enabled=no\r\
\n/interface sstp-server server set enabled=yes\r\
\n:log warning \"CPU Load \$cpuload reenabled sstp service\"\r\
\n}"
/system scheduler
add disabled=no interval=5m name=cpuloadsstp on-event="/system script run cpuload" policy=ftp,read,write,winbox,api start-date=\
sep/28/2012 start-time=07:00:33
kind regards
odge
Re: CPU 100% PPP
Sat Oct 13, 2012 3:40 pm
Thanks, disabling SSTP server workaround works.
Users browsing this forum: darkprocess, jonah1810, mada3k, Vossberger and 113 guests
