norenberg
Can't make Port FWD for multiple IP's
Thu Sep 27, 2012 8:01 am
I have multiple public IP's and I have NAT port forwarding for multiple services.
When I input a new WAN IP and route it ie a PPPoEout connection, it drops the NAT for all the others.
For instance, if I have this:
 0 A S  0.0.0.0/0                          10.0.0.2                  5
 1   S  0.0.0.0/0                          202.1XX.5x.X              5
 2 X S  0.0.0.0/0                          192.168.3.1               5
 3 ADS  0.0.0.0/0                          2XX.8X.5x.1               1  ALL SERVICES NAT TO THIS
So, say that I add a new PPPoE OUT connection:
 1 A S  0.0.0.0/0                          203.1xx.5x.1              5
I can't make any NAT through this one above. Can't ping from external, can't do anything.
And if I mark "Add Default Route" I can ping from outside but it kills all the other PPTP and NAT's port fwd from the 202.1XX.5x.X , for example:
13 X ;;; Backup
     chain=dstnat action=dst-nat to-addresses=192.168.1.20 to-ports=80
     protocol=tcp dst-address=202.1XX.5x.X  dst-port=8080
This stops working.
Any clue on why is this happening?
Cheers
norenberg
Re: Can't make Port FWD for multiple IP's
Thu Sep 27, 2012 11:54 pm
Was my question understandable?
janisk
Fri Sep 28, 2012 12:16 pm
paste more configuration as it is not clear what ou have set up where. what masquerade (srcnat) you have.have.
AnRkey
Fri Sep 28, 2012 12:35 pm
Post the output of /ip firewall nat print for us please.
Also, you an only have one default gateway unless you label traffic and then route by label. This is the only way, that I'm aware of, to have multiple default gateways at once.
Having two default gateways will result in only one of them being used.
MTCNA
norenberg
Fri Sep 28, 2012 5:30 pm
Thanks everyone for the reply.
AnRkey
This makes sense, I do use marked routes, but someone has done this for me.
Now I need to be onsite to check this out (I don't wanna risk to do it remotely.)
I use masquerade for hotspots and multiple VLANs but I believe routing-marks will be the culprit.
I will post the follow-up here for reference.
cheers
norenberg
Tue Oct 23, 2012 5:44 am
Ok, I am using route marks and I can get the outgoing connection to work fine.
However, I still not able to make the IP to respond to incoming connections.
Any advice?
 1   chain=prerouting action=mark-routing new-routing-mark=residential
     passthrough=yes src-address-list=pppoe dst-address-list=!local
;;; Backup VDSL
     protocol=tcp dst-address=203.171.5X.XXX routing-mark=residential
     dst-port=8080
I just can't connect to the port 8080 :(
Cheers, thanks for any advice.
janisk
Tue Oct 23, 2012 12:32 pm
if yo have several WAN connections and you want to use them both then
1. mark routing, so traffic knows where to go out, like some load balancing (seems you have this)
2. you have to mark incoming connections and assign them wan routing marks so packets that came it WAN1 will go out WAN1 not any other of available WAN interfaces
3. if you want NAT to specific addresses you can use 1 to 1 map or use specific source nat rule to NAT specific addresses to specific global address.
norenberg
Tue Oct 23, 2012 11:14 pm
Thanks for your reply.
I'd like to make a port mapping. Do you mean:
 chain=srcnat action=src-nat to-addresses=203.171.5X.XXX to-ports=8080
     protocol=tcp src-address=192.168.1.20 routing-mark=residential src-port=80
tried this but still didn't work
janisk
Wed Oct 24, 2012 9:05 am
here you can read about 1 to 1 mapping and how that operates:
http://wiki.mikrotik.com/wiki/Manual:IP ... :1_mapping
norenberg
Thu Oct 25, 2012 11:30 pm
Your docs appear to have wrong information (replace ips for the real ones):
/ip firewall nat add chain=dstnat dst-address=11.11.11.1-11.11.11.254 \
	action=netmap to-addresses=2.2.2.1-2.2.2.254
failure: netmap action requires to-address be whole network
Managed to netmap anyway:
23   ;;; Netmap
     chain=dstnat action=netmap to-addresses=192.168.1
     dst-address=202.171.XXX.1-202.171.XXX.254 routing-mark=residential
24   chain=srcnat action=netmap to-addresses=203.171.5
And, guess what? Still not working.
No ping, no access from external. DST-NAT won't work.
Any ideas?
janisk
Fri Oct 26, 2012 8:27 am
this will work for example ip addresses from manual.
/ip firewall nat add chain=srcnat src-address=2.2.2.0/24 \
action=netmap to-addresses=11.11.11.0/24
/ip firewall nat add chain=dstnat src-address=11.11.11.0/24 \
updated manual to reflect on changes that where done
this will work:
/ip firewall nat add chain=dstnat dst-address=11.11.11.0-11.11.11.255 \
	action=netmap to-addresses=2.2.2.0-2.2.2.255
/ip firewall nat add chain=srcnat src-address=11.11.11.0-11.11.11.255 \
idea behind is that x.x.x.0/24 translates to x.x.x.0-x.x.x.255 since /24 includes x.x.x.0 and x.x.x.255 and these addresses are perfectly fine for example, when pppoe is used and tunnel remote address is x.x.x.0/32 or x.x.x.255/32 or something that we are more used to as x.x.x.254/32
Users browsing this forum: Google [Bot], sirbryan and 112 guests
