utocava
valley 6km
Fri Sep 28, 2012 4:57 pm
Hello.
This is my first post.
I am using Ubnt and Mikrotik devices to cover the valley I am living in. (pics attached).
Using Ap1.Ap2 Omnitik-Mikrotik
CPEs - Sxt - mikrotik.
because some customers are 6-7km far, do you know what can I use instead?
regards
rodolfo
Long time Member
Long time Member
Re: valley 6km
Fri Sep 28, 2012 9:34 pm
you cannot use omnitik, you must use a sector antenna 60°
to the antenna attach a Groove A-5Hn.
rodolfo
IZ0UQV
utocava
Re: valley 6km
Fri Sep 28, 2012 11:19 pm
why not an omnitik?
what sectorial 60*,any brands you advice me?
andressis2k
Re: valley 6km
Sat Sep 29, 2012 2:27 am
These customers... are all them together? Or are them dispersed?
You must specify how long is the zone you want to cover, so we can calculate how many degrees do you need.
Omnitik is a omnidirectional device, and won't work fine in that scenario.
For example, if you want to cover a 2km village that is 7km away, you may need a 17º antenna, so you must use a panel.
You can even use a Sextant, buying a L4 license, or replacing the internal board with a more powerful one (how many users do you want to offer service?)
For a more professional, you can use any other panel antenna (like Itelite PRA50019) with a routerboard inside it
If he use SXT as CPE, as he sais, using a SISO antenna and access point isn't a good thing. It will decrease the performance and make bottleneck.
I'd recommend to use 2x2 MIMO antenna and AP
Regards
utocava
Re: valley 6km
Sat Sep 29, 2012 10:32 am
Hi,customers are sometimes dispersed,sometimes together.depending.
The zone i want to cover is 3-4km long and is 5-6km away.
Any advice?=
rodolfo
Long time Member
Long time Member
Re: valley 6km
Sun Sep 30, 2012 11:33 am
you cannot attach a sector antenna to an omnitik.
You need on detached router+radio each Sector antenna.
The cheaper way is to use a Groove 5HnA + a 90° vertical sector antenna.
rodolfo
IZ0UQV
Users browsing this forum: No registered users and 85 guests
