MUM Europe 2020
milbr.net
RB 1100 lock service SSH OS V. 5.20
Tue Oct 02, 2012 5:56 pm
Good Morning
We have a problem and can not identify, we have a 1100 RB RouterOS V. 5:20 doing PPPOE authentication, 200 simultaneous users.
We use a check where our need to make a SSH server, however within two days it does not happen again, I can not open terminal or internal. The RB does not lock but does not run over SSH.
Could you help me? :?
milbr.net
Re: RB 1100 lock service SSH OS V. 5.20
Tue Oct 02, 2012 10:52 pm
Nobody can help????
smile__2006
Thu Oct 04, 2012 2:53 pm
see http://forum.mikrotik.com/viewtopic.php?f=2&t=65239, but no answer from support(((
chojrak11
Mon Oct 15, 2012 1:04 pm
I have the same problem (no PPPoE, but over 150 PPTP users, 10-20 simultaneously active). 2-3 days uptime everything is OK, then terminal and ssh stop working.
What most amazed me, I wanted to generate supout file to attach to support mail, and just after clicking "Make supout.rif" in Winbox everything immediately went back to normal. Do this: open terminal window, observe that it doesn't work then click "Make supout.rif". The prompt appears after 1-2 sec, and subsequent terminal windows are most of the time ok -- however after 14 or more days of uptime that hack may not help.
And the reboot can be fragile too, it can panic during reboot.
smile__2006
Mon Oct 15, 2012 6:46 pm
Does any of support team reading this)( ?
It`s very bad to reboot router in production area
flop.m@usa.net
Tue Oct 23, 2012 1:19 pm
I just upgraded my router from 5.18 to 5.21 and I cannot connect to my router via SSH anymore. It was working perfectly fine for years before the upgrade. Now, I only get following error on my SSH client
ssh_exchange_identification: Connection closed by remote host
Any help to solve this ?
Thx
jp
Long time Member
Long time Member
Re: RB 1100 lock service SSH OS V. 5.20 and x86.
Tue Oct 23, 2012 8:59 pm
I've got this on an x86 box that does not do pppoe or pptp. your trick fixes it.
flop.m@usa.net
Wed Oct 24, 2012 11:22 am
Thx
For some reason, I haven't noticed that the security package has not been upgraded! So, I uploaded it again, and now no more problems with the ssh connection.
So, check that the security package is still there after an upgrade. And I 100% sure I did upload it before upgrading from 5.18 to 5.21.
Issa
chojrak11
Wed Oct 24, 2012 2:18 pm
Checked, and every affected router has all packages versions 5.21. I don't upload each package separately, but use one .npk file to upgrade all at once.
zdiv
Mon Oct 29, 2012 11:55 am
From some strange reason npk for 5.21 does not install security package.
workaround: install security package from zip file.
upgrade from 5.20 to 5.21
X86 system
other packages where not installed as well.
List of missing packages after upgrade:
security
routing
mpls
advanced-toolsmulticast
user-manager
wireless
ppp
ntp
lcd
kvm
gps
Users browsing this forum: rjscomms and 66 guests
