Ehman
No-Ip script giving me probles
Tue Oct 09, 2012 3:46 am
I found this thang on the internet and it looks like the best one so far, the but after testing it out, it gives out internal IP's like instead of external ip, it updates my host with 192.168.5.1 things like that, and if I use the windows one, and run in on the windows box, it works 100%, but I have my router to run this script.
so my problem is, the script is uploading private IP's and thats useless to beyond
# No-IP automatic Dynamic DNS update
#--------------- Change Values in this section to match your setup ------------------
# No-IP User account info
:local noipuser "your_no-ip_user"
:local noippass "your_no-ip_pass"
# Set the hostname or label of network to be updated.
# Hostnames with spaces are unsupported. Replace the value in the quotations below with your host names.
# To specify multiple hosts, separate them with commas.
:local noiphost "hostname.no-ip.net"
# Change to the name of interface that gets the dynamic IP address
:local inetinterface "your_external_interface"
# No more changes need
:global previousIP
:if ([/interface get $inetinterface value-name=running]) do={
# Get the current IP on the interface
:local currentIP [/ip address get [find interface="$inetinterface" disabled=no] address]
# Strip the net mask off the IP address
:for i from=( [:len $currentIP] - 1) to=0 do={
:if ( [:pick $currentIP $i] = "/") do={
:set currentIP [:pick $currentIP 0 $i]
:if ($currentIP != $previousIP) do={
:log info "No-IP: Current IP $currentIP is not equal to previous IP, update needed"
:set previousIP $currentIP
# The update URL. Note the "\3F" is hex for question mark (?). Required since ? is a special character in commands.
:local url "http://dynupdate.no-ip.com/nic/update\3Fmyip=$currentIP"
:local noiphostarray
:set noiphostarray [:toarray $noiphost]
:foreach host in=$noiphostarray do={
:log info "No-IP: Sending update for $host"
/tool fetch url=($url . "&hostname=$host") user=$noipuser password=$noippass mode=http dst-path=("no-ip_ddns_update-" . $host . ".txt")
:log info "No-IP: Host $host updated on No-IP with IP $currentIP"
} else={
:log info "No-IP: Previous IP $previousIP is equal to current IP, no update needed"
} else={
:log info "No-IP: $inetinterface is not currently running, so therefore will not update."
3. Create a new scheduler entry to run this script every 5 mins.
/system scheduler add comment="Update No-IP DDNS" disabled=no interval=5m \
name=no-ip_ddns_update on-event=no-ip_ddns_update policy=read,write,test
jandafields
Re: No-Ip script giving me probles
Tue Oct 09, 2012 4:30 am
Does the external interface of your router (that you have typed into the script) have a private IP?
Ehman
Tue Oct 09, 2012 12:48 pm
I typed
:local inetinterface "ether10"
and my ether10 goes in my adsl router
Users browsing this forum: No registered users and 99 guests
