radiosn00p
MT fails to reboot when instructed to..
Sat Feb 04, 2006 12:41 am
I am using a giga-byte 8S661FXM SiS Socket 775 series motherboard with level-5 router os 2.9.11. When I tell the router to reboot or shut-down, it never completes the process. HELP! I have checked all that I can in BIOS and elsewhere. I'm using 2.9.12 on DOM, 512M of RAM and Intel P4 2.66 GHz
cibernet
Long time Member
Long time Member
Re: MT fails to reboot when instructed to..
Sun Feb 05, 2006 6:09 am
Have you tried to change the motherboad?
José Ignacio Acosta
MikroTik Consultant IDAR0001
Mikronet
Movile: +54 9 3472-624722
Email/Msn: info[at]mikronet.com.ar
andrewluck
Forum Veteran
Forum Veteran
Sun Feb 05, 2006 12:37 pm
BIOS update?
radiosn00p
Mon Feb 06, 2006 3:56 pm
They are brand new, and have the latest BIOS versions.
djape
Mon Feb 06, 2006 4:59 pm
I know this will sound crazy, but try by adding routerboard package. You need to reboot (it will still hang) but after you confirm that routerboard.npk is there it should reboot without problem from know on...
I drink like a pirate and smoke like a hippie...
radiosn00p
Mon Feb 06, 2006 5:11 pm
It already has routeboard package installed.
djape
Mon Feb 06, 2006 9:48 pm
Then there is something wrong with the hardware...
Users browsing this forum: Baidu [Spider], Google [Bot] and 74 guests
