gmsmstr
Trainer
Trainer
Block Hotspot Users
Sat Feb 04, 2006 8:14 pm
How do I make it so that only port 80 and 443 can be used though my hotspot?
Hellbound
Long time Member
Long time Member
Sat Feb 04, 2006 11:19 pm
should be like this
/ip firewall filter add chain=input dst-address=!10.1.1.1/32 dst-port=!80 action=drop
/ip firewall filter add chain=input dst-address=!10.1.1.1/32 dst-port=!443 action=drop
10.1.1.1 is the router ip so you can allow yourself to connect to the router without hassle
savage
Sat Feb 04, 2006 11:46 pm
Through his hotspot.
Should that not be forwarding chain??? :?
Regards,
Chris
ofasa
Sun Feb 05, 2006 12:02 am
should be like this
Then port 443 wil get droped before it gets to the second rule.
It should be:
port=80 action=accept
port=443 action=accept
anything else action=drop
Users browsing this forum: fposavec, MarcDE and 59 guests
