MUM Europe 2020
honzam
rb133c NOT responding after upgrade to 6.0rc3
Tue Oct 30, 2012 6:03 pm
Upgrade FAIL from 5.20 to 6.0rc3 (2012-10-30 14:55:15)
see console (in next my post) - during upgrade
after power cycle - routerboard boot but very long time to starting services
then - unable login via console, no PING (it seem like 100% cpu)
LAN, FTTx, Wireless. ISP operator
jandafields
Re: rb133c dead after upgrade to 6.0rc3
Tue Oct 30, 2012 6:09 pm
see console - during upgrade
Do a netinstall back to 5.x to fix the router.
Please report this error to support@mikrotik.com
honzam
Tue Oct 30, 2012 6:31 pm
Console:
http://ulozobrazek.cz/view.php?filename ... 3_fail.jpg
I dont need netinstall, this is test on table :)
This is report
jandafields
Tue Oct 30, 2012 6:47 pm
Console:
This is report
Ok, I see. I thought you were asking how to fix it.
All reports like this must be sent to support@mikrotik.com. Posting them on the forum won't get them to the right place.
honzam
Thu Nov 01, 2012 3:01 pm
I tried new build (2012-10-31 11:09:44) via netinstall
jandafields
Thu Nov 01, 2012 3:07 pm
honzam
Thu Nov 01, 2012 4:08 pm
Do you known this button? Support is informed
normis
Thu Nov 01, 2012 4:10 pm
Device is not "dead", because you can use Netinstall to downgrade to v5.21. We will see why v6 doesn't work, but remember - RB133c only has 16MB of RAM and was made some 7 years ago ...
honzam
Thu Nov 01, 2012 5:17 pm
I known. Downgrade to 5.21 works well. Rb133c is very OLD product, but you newer say -> ROS 6.0 is incompatible with old MIPSLE boards
I hope that ROS 6.0 will work with rb532 and rb133C. If not please warn users on webpage...
honzam
Tue Nov 06, 2012 5:12 pm
build from this day
normis
Wed Nov 07, 2012 8:31 am
build from this day
Also on RB133c? Yes, because we have made no changes yet.
it works on all other MIPS-LE boards because they have more RAM. RB113C and RB112 are the only exceptions.
honzam
Wed Nov 07, 2012 9:09 am
And will work ROS6 in the future on rb133c and rb112 ?
normis
Re: rb133c NOT responding after upgrade to 6.0rc3
Wed Nov 07, 2012 9:11 am
It works if you install only System package. Check which packages you can omit, and install only the very basics. It could work then.
honzam
Wed Nov 07, 2012 11:29 am
I can try it, but where download all packages rc3? On prerelase is only mipsle-6.0rc3.npk
normis
Wed Nov 07, 2012 11:31 am
currently nowhere. we will see what we can do.
honzam
Tue Nov 13, 2012 4:08 pm
Normis, now I try install only system package 6.0RC3
The same problem - kernel panic
boardman
Fri Jun 28, 2013 12:20 am
Too late, few RB133c unuseable after ROS6.1 installed ... replaced some by RB411 and some with NSM5.
Cost, crew, time, upset customers involved ..... Next time please ADVICE on download or changelog.
JB
honzam
Fri Jun 28, 2013 9:17 am
And what is this?
The first post was written at a time when no warning on download page
normis
Fri Jun 28, 2013 9:29 am
This note is there, since RouterOS v6 rc1 was released
boardman
Fri Jun 28, 2013 4:42 pm
Ok, thanks
Users browsing this forum: maximo, MSN [Bot] and 122 guests
