MUM Europe 2020
kapulan
port forward all network users!how to?
Tue Feb 07, 2006 8:11 pm
Hello!
A have little problem!My network is connected 15 local lan users!How to forward all users the 6881 bitorrent port?The Dst address ist to receive the dhcp server automatice.My local lan have static ip address.How to forward all users the bitorrent port?
Am sorry not write good english!
Thank you for your help in advance!
Borage
Tue Feb 07, 2006 8:39 pm
You cannot forward port 6881 to all 15 computers, only one computer.
dot-bot
Tue Feb 07, 2006 10:19 pm
Mnaaah just use UPnP - start the UPnP service on the local interface on MT and enable UPnP on all 15 BitTorrent client applications. If UPnP is not supported try another client like uTorrent that supports it. NOT TESTED
or if want to do it the oldschool way:
You'll have to set up each puter to use a different outgoing port and write it down. Then on MT forward each port you wrote down to the puter thats using it. How to forward a port this way is described in the manual.
The server's address is now 192.168.0.4, and we are running web server on it that listens to the TCP
port 80. We want to make it accessible from the Internet at address:port 10.0.0.217:80. This can be
done by means of Static Network Address translation (NAT) at the MikroTik Router. The Public
address:port 10.0.0.217:80 will be translated to the Local address:port 192.168.0.4:80. One
destination NAT rule is required for translating the destination address and port:
[admin@MikroTik] ip firewall nat> add chain=dstnat action=dst-nat protocol=tcp
dst-address=10.0.0.217/32
dst-port=80 to-addresses=192.168.0.4
[admin@MikroTik] ip firewall nat> pr
0 chain=dstnat dst-address=10.0.0.217/32 protocol=tcp dst-port=80
action=dst-nat to-addresses=192.168.0.4 to-ports=0-65535
Where you add as much as these rules as you need, change port 80 to whatever port you wrote down for each puter and IP address 192.168.0.4 to each IP of your 15 machines. 10.0.0.217->replace this with your gateway IP address or leave IP address fielt blank if you setup the rule for the public interface.... Consult the manual if confused.
raulborda
Re: port forward all network users!how to?
Wed Feb 08, 2006 1:08 am
Hello!
This is imposible to do. What is the porpouse for this?.
When you redirect the 6881 port to a lan client, is imposible redirect the same port for another client.
djape
Wed Feb 08, 2006 4:27 pm
He is trying to make upload on torrents to work faster :D
Don't worry about stupid torrent clients that offer you to test connection, just leave it as it is....
Cheers....
I drink like a pirate and smoke like a hippie...
dot-bot
Wed Feb 08, 2006 7:33 pm
Leave what as it is ?
DO NOT leave torrent clients incapable of opening a port.
djape
Thu Feb 09, 2006 5:26 pm
Hey!
You can use torrent with masquarading only!
So don't touch anything as I said, I NEVER said he should block those ports...
dot-bot
Sun Feb 12, 2006 7:35 pm
kapulan, if your 15 users are behind a NAT do what I said in my first post and thats it. If they have real internet IP addresses, you most probably do not have to change anything. Opening a port will then be a matter of firewall configuration, seeing if firewall is turned on for all ports.... Maybe firewall apps on client puters...
djape
Sun Feb 12, 2006 9:21 pm
Hey dot-bot, you wanna fight with me ? :D
dot-bot
Sun Feb 12, 2006 9:37 pm
Your tips can not be understood or are simply not true. Try explaining more in plain English what are you trying to say here or where do we fail to understand each other.
djape
Sun Feb 12, 2006 11:57 pm
I wanted to say that he should just use masquarade and torrents will work without any problem for as much pc's as he want- nothing more.
kapulan
Sun Feb 19, 2006 7:10 pm
Hey!
How can you make the masquarading?
cibernet
Long time Member
Long time Member
Sun Feb 19, 2006 10:39 pm
Hey!
ip firewall nat add chain=srcnat src-address=(your lan) action=masquerade
Regards....
José Ignacio Acosta
MikroTik Consultant IDAR0001
Mikronet
Movile: +54 9 3472-624722
Email/Msn: info[at]mikronet.com.ar
acim
Mon Feb 20, 2006 12:03 am
@djape
Do you want to say that masquerade works better than src-nat regarding torrent clients?
I mean are there any differences between
chain=srcnat out-interface=link action=masquerade
and
chain=srcnat out-interface=link action=nat to-addresses=x.y.z.w
in this manner? I know other differences between these two, but I was not aware of torrent clients related differences.
@all
I use masquerade form of NAT and Shareaza works better if I dst-nat some port from WAN interface with public IP to some machine on local network. But, if you need to support many machines with torrent clients this way, I supose UPnP is the best solution, although I haven't tried it in my network because P2P software can just make bandwidth problems and I don't want to courage my users to use it a lot.
djape
Tue Feb 21, 2006 1:08 am
@djape
and
No, it doesn't make any difference, it's just working the same using masquarade or with src-nat and dst-nat. I tried it myself and there is no difference. I have whole subnets using torrents with masquarade without problem.
Cheers...
Users browsing this forum: ferastemimi, gibi13, Horci, rioven, Z0ltan and 122 guests
