MUM Europe 2020
znhost
BGP ERROR
Sat Nov 10, 2012 9:52 pm
i want to route my subnet ip with as number in mikrotik os. Datacenter say me we must run BGP and give me datacenter router ip and as number.
at first i go to routing -> BGP ->instances
and add new with 'BGP' name and my AS and mikrotik ip address as router id.
then add new peers with instance 'BGP'
remote address = (datacenter router id)
remote as = (datacenter as)
nexthop choice = default
multihop ticked
holdtime 3
ttl 5
default originate never
in advanced
address families : ip ticked
update source none
cisco vpls nlir length format: auto bits
and in network tab i add new with my ip format like this : 79.23.35.15/24
in a log file i see :
failed to open tcp connection: connection refused
remote address= (datacenter router id)
can you help me for this issue?
Chupaka
Re: BGP ERROR
Sat Nov 10, 2012 11:36 pm
In your peer, 'Advanced' tab, set 'Update Source' to the IP address datacenter setup as your BGP peer. seems like your BGP connection is being established from the wrong address
also, check firewall filter rules in input and output chains
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
znhost
Re: BGP ERROR
Sun Nov 11, 2012 12:12 am
thanks for your replay Chupaka
i dont have any firewall filter rules in mikrotik.
i edit Update Source , but now i faced problem.
check the attachment
znhost
Re: BGP ERROR
Sun Nov 11, 2012 10:34 pm
problem solved. datacenter router make this problem.
lakmalv
Re: BGP ERROR
Fri Feb 14, 2020 10:26 am
I am also gettin this error. How did you fix it? I have a mikrotik CCR router conncted to the ISP at datacenter. I can ping ISP router and have internet access as well. But when I create a peer it says Failed to open a tcp connection , connection refused.
IPANetEngineer
Trainer
Trainer
Re: BGP ERROR
Fri Feb 14, 2020 1:09 pm
This meas TCP port 179 for BGP is not answering on the remote end which can be one of several things
1) The source of your peering
2) Firewall rules
3) Issue with the router you are peering with.
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
Users browsing this forum: imdadali, k6ccc, McSee, naxos, wispmikrotik and 136 guests
