geraldv
Help .. Routerboard generating own traffic on internet side
Tue Nov 13, 2012 12:11 am
Hi All
Apologies if I have posted incorrectly, I am a noobie.
I am using a RB405G on OS 5.16 .. A dealer supplied and configured it.
We are experiencing a strange traffic phenomenon several times a day only on the external network side.
The router just starts sending and receiving traffic continuosly on the external side only. Coupled with this is cpu at +50% usage.
It gets so bad that normal internet use slows down to a dribble. I have unplugged the internal side of the network and it continues like this.
I have to disconnect the internet side and leave for a few minutes and reconnect, then everything returns to normal again.
This is resulting in incredibly high internet bandwidth usage been reported by my ISP.
There is a huge usage stat difference seen between the internal port and the external port. With the external port been +30% higher than internal side.
In last 30days internal = 200Gig / External =300Gig.
With internal side disconnected the RB firewall still shows many active connections sending and receiving at a high rate.
Anybody got any suggestions how to sort this out?
Thanks in advance.
regardtv
Re: Help .. Routerboard generating own traffic on internet s
Thu Nov 15, 2012 12:44 am
I'd suggest you see if you have "/ip proxy" enabled - if you do, firewall it so only your interal IPs can get to it.
~If I helped please give me Karma - its free after all~
I make these posts in my personal capacity.
NAB
Trainer
Trainer
Thu Nov 15, 2012 1:32 am
Likewise, check you don't have an open DNS resolver (may be being used for an amplification attack).
Users browsing this forum: Bing [Bot] and 124 guests
