MUM Europe 2020
ronniee
error message: got deauth: class 3 frame received(7) HELP?
Wed Feb 08, 2006 10:09 am
hello,
I have a problem with a MT box(v2.9.10) + Senao NL-5354MP Plus Aries2(F) with Atheros minipci card setted in 5Ghz in AP Bridge mode.
I want to connect have 3 clients with PCI wireless card model: PC-6860 802.11 a/b/g PCI card atheros chipset.
the 3 clients can't connecty in the same time, the 3th every time got the:
wlan1: disconnected xx:xx:xx:xx:xx:xx, got deauth: class 3 frame received(7)
OR
wlan1: disconnected xx:xx:xx:xx:xx:xx, got deauth: sending station leaving(3)
and is disconected from the AP
If the Default Authenticate is enabled or not, the clients are in AccessList alowed, is the same problem.
If somebody can help me, is very important
thanks,
ronniee
cibernet
Long time Member
Long time Member
Re: error message: got deauth: class 3 frame received(7) HEL
Wed Feb 08, 2006 10:16 am
hello,
thanks,
ronniee
Upgrade to 2.9.12 and see if stil happend
Regards
José Ignacio Acosta
MikroTik Consultant IDAR0001
Mikronet
Movile: +54 9 3472-624722
Email/Msn: info[at]mikronet.com.ar
ronniee
Wed Feb 08, 2006 1:25 pm
i don't know is the upgrade will solve the problem
the MT routerboard is on-line now with other 3 minipci in 2,4Ghz band, and I can't turn off for much time
i will study now the upgrade procedure, and how will affect an working MT with 3 dhcp servers and 100 leased IPs with simple queues etc.
after upgrade the setting will be lost?
thanks
ronniee
cibernet
Long time Member
Long time Member
Wed Feb 08, 2006 1:28 pm
thanks
ronniee
No, the settings will remain there :wink: , you will not loose nothing :D , make a backup to be sure that you will recover the settings if something goes wrong...
Regards
José Ignacio Acosta
Mikronet
Users browsing this forum: Costa and 133 guests
