MUM Europe 2020
normis
Newsletter 42
Wed Nov 14, 2012 12:58 pm
5 pages this time!
http://download2.mikrotik.com/news-42.pdf
Cloud Core Router pricing
RB2011 new models
Academy news
MUM news and videos
Hidden feature - cable problems
RouterOS v6
Trisc
Re: Newsletter 42
Wed Nov 14, 2012 1:31 pm
Hidden features: cable problems. Should this work on the RB750UP? Not seeing anything different here.
normis
Re: Newsletter 42
Wed Nov 14, 2012 1:36 pm
Do you have RouterOS v5.21 and latest RouterBOOT (check routerboard upgrade menu). I can see it on mine
Trisc
Re: Newsletter 42
Wed Nov 14, 2012 1:40 pm
Yup. 5.21 and 3.0 firmware
normis
Re: Newsletter 42
Wed Nov 14, 2012 1:41 pm
post output of command "/interface ethernet monitor [find]"
Trisc
Re: Newsletter 42
Wed Nov 14, 2012 1:44 pm
[admin@MikroTik] > /interface ethernet monitor [find]
status: link-ok link-ok no-link link-ok no-link
auto-negotiation: done done done done done
rate: 100Mbps 10Mbps 10Mbps 100Mbps 10Mbps
full-duplex: yes no no yes no
-- [Q quit|D dump|C-z pause]
normis
Re: Newsletter 42
Wed Nov 14, 2012 1:55 pm
We tested with v6rc3, we will have to fix the manual. Some devices were added in v5, some only in v6
Trisc
Re: Newsletter 42
Wed Nov 14, 2012 2:04 pm
Better fix the newsletter as well :)
So which devices do work in 5.21?
ckgth
Re: Newsletter 42
Wed Nov 14, 2012 3:10 pm
2011 with 5.21 and 3.0 works also no.
regards
Christian
normis
Re: Newsletter 42
Wed Nov 14, 2012 3:23 pm
so far it looks like driver is in v5.21, but console doesn't show relevant info.
only RouterOS v6 supports the cable diagnostic at this point
honzam
Re: Newsletter 42
Wed Nov 14, 2012 6:28 pm
And 5.22 will support Cable test?
LAN, FTTx, Wireless. ISP operator
infowest
Re: Newsletter 42
Wed Nov 14, 2012 8:58 pm
I believe it's not working at all on RB750GL. I tried on 5.21, then upgraded to the 6.0RC:
[admin@WestRidgeSwitch1] /interface ethernet> /sys resource print
                   uptime: 16m15s
                  version: 6.0rc3
              free-memory: 50348KiB
             total-memory: 61876KiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 400MHz
                 cpu-load: 2%
           free-hdd-space: 51208KiB
          total-hdd-space: 61440KiB
  write-sect-since-reboot: 1120
         write-sect-total: 359903
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: RB750GL
                 platform: MikroTik
[admin@WestRidgeSwitch1] /interface ethernet> /system routerboard print
       routerboard: yes
             model: 750GL
     serial-number: 3B06020B2008
  current-firmware: 3.0
  upgrade-firmware: 3.0
[admin@WestRidgeSwitch1] /interface ethernet> monitor [find]
              status: no-link no-link no-link no-link link-ok
                rate:                                 100Mbps
         full-duplex:                                 yes
normis
Re: Newsletter 42
Thu Nov 15, 2012 8:40 am
750GL, 750, SXT G, 711G, 2011 will be added in v6rc4
nz_monkey
Re: Newsletter 42
Thu Nov 15, 2012 10:30 am
Sweet.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
Łukasz
Re: Newsletter 42
Mon Nov 26, 2012 6:55 pm
Most of the links do not work. For example, on the last page.
sergejs
Re: Newsletter 42
Tue Nov 27, 2012 4:05 pm
Łukasz,
thank you very much for the report.
We will fix links in the newsletter.
normis
Re: Newsletter 42
Wed Nov 28, 2012 4:00 pm
this is normal for portable devices like phones and tablets. it works fine on a PC using Acrobat reader
Łukasz
Re: Newsletter 42
Thu Nov 29, 2012 10:13 pm
I tried on PC with win xp sp2 and acrobat reader 10.1.4.38.
Link on first page work without issue. Links on last page does not work.
infowest
Re: Newsletter 42
Fri Nov 30, 2012 12:49 am
No luck with cable monitoring in RC4 on RB750GL.
infowest
Re: Newsletter 42
Fri Nov 30, 2012 1:23 am
... But it does work on the RB2011L FastE ports.
ronix
Re: Newsletter 42
Mon Dec 10, 2012 11:42 am
Dear Mikrotik Support....
Link on first page work fine. Links on last page does not work
Please if you solve the problem & if you post here the link of cable diagnostics
Reagards
normis
Re: Newsletter 42
Mon Dec 10, 2012 11:43 am
Reagards
are you using a mobile phone to view it? links work on Adobe Reader
ronix
Re: Newsletter 42
Mon Dec 10, 2012 12:20 pm
PC with winxp sp3 + adobe reader 10.1.1
Basiley
Re: Newsletter 42
Mon Dec 10, 2012 3:23 pm
to view Acrobat/PDF - prefer eVince[even on Windows].
nice[but short/formal] CCR presentation.
also ROS 6.0 short promo -)
p.s.
WebFig fully working only on Chrome or MSIE. had minor issues on Opera and more serious on recent Firefox[17?] and Sea-monkey[2.14.1], for example - menus stuck in "Quick Set" page/caps regardless what/how you click in icon tree :(
chadd
Re: Newsletter 42
Sat Jan 05, 2013 7:01 am
Normis,
Happy to see the 2.4Ghz sxt.
Here in the states we really could use a ~14dBi and ~19dBi version also. We are still having to cobble together 711's and mix and match dual pol client antennas for dual chain NV2. Are you guys working on anything other than the 10dBi version?
Thanks,
Chadd
normis
Re: Newsletter 42
Sat Jan 05, 2013 9:36 pm
19dBi for 2GHz would be very big, not SXT size. So we would have to have another product line then.
remotelylocated
Newsletter 42
Sat Jan 05, 2013 9:41 pm
19dbi @ 2ghz would be nice to see. About 16" across. More than likely one of your best sellers.
Sent from my iPhone using Tapatalk
Jason Wilson
Remotely Located Inc.
Providing High Speed Internet to out of the way places.
530-651-1736
http://www.remotelylocated.com
chadd
Re: Newsletter 42
Thu Jan 10, 2013 9:41 pm
I hope you guys are working on it because it is a product that is needed, at least in the US. We are currently having to order 19dBi dual pole antenna/enclosures from China and assembling them with 2HnD boards to make up our clients. Also a 2Ghz omnitik would be really nice to see.
chadd
Re: Newsletter 42
Thu Jan 10, 2013 9:43 pm
Yep not many uses for anything under 14dBi in our area at least, 19dBi is our most used CPE.
Users browsing this forum: mkrz, MSN [Bot], pukkita and 134 guests
