poweruser
How to reboot the routerOS without rebooting the computer?
Thu Nov 15, 2012 1:43 pm
Is there any possibility to reboot running routerOS without rebooting the whole computer?
I have problem with RouterOS v5.20. It needs to be rebooted after aproximately 15-20days of running(no password set, no licence, dont save any changes, cant download a file and so on...) but my computer(core i5 2400) sometimes doesnt see USB disk after reboot so it cant load the routeros software from it and stays stuck.
Thanks for helping me.
NAB
Trainer
Trainer
Re: How to reboot the routerOS without rebooting the compute
Thu Nov 15, 2012 1:49 pm
If ROS is running on the bare metal, then no.
My guess is that your problem is with USB. If it's a standalone machine running ROS, then I would strongly recommend putting a HDD inside it connected over IDE/SATA. My experience of USB devices with ROS is not good!
poweruser
Thu Nov 15, 2012 5:09 pm
Thanks.
There wouldnt be any problem if the ROS wouldnt freeze in such a way I have described. The PC is running on large UPS so there wouldnt be any problem with turning on/off due electricity failures and than with USB boot failure(only sometimes but it still happens sometimes).
NAB
Trainer
Trainer
Fri Nov 16, 2012 10:54 am
What I am saying is that I suspect your ROS is freezing because the USB or USB disk is failing. Seriously, put an IDE/SATA drive inside the box and don't use USB.
Users browsing this forum: Baidu [Spider], Google [Bot], Majestic-12 [Bot] and 62 guests
