cnokafor
3G USB modem on RouterOS
Fri Nov 16, 2012 5:39 pm
How can i make use of 3G USB internet modem on my routerboard 751u. It comes with USB port but i can't get the routerOS to work with the privider (GSM) and access internet.
ohara
Re: 3G USB modem on RouterOS
Fri Nov 16, 2012 5:51 pm
Go through these steps:
1) is your usb modem supported by ROS?
2) did you plug it in and do you see ppp-out1 interface?
3) did you set the correct data channel and info channel in ppp-out1 properties?
4) did you set correct APN name in properties?
5) last but not least, did you add nat rule?
/ip firewall nat add action=masquerade chain=srcnat disabled=no out-interface=ppp-out1
further reading: http://mybroadband.co.za/vb/showthread. ... -3G-Modems
cnokafor
Fri Nov 16, 2012 6:30 pm
How do i know RouterOS suppots my usb modem or what do you mean by ROS?
vadyalex
Fri Nov 16, 2012 8:00 pm
By ROS he meant Router OS.
You can take a look here for supported hardware: http://wiki.mikrotik.com/wiki/Supported_Hardware
darkkiss
Thu Feb 07, 2013 5:43 pm
ZTE MF110 works fine.
In case there are other users having problems configuring this modem :
[dark@RB951G] > interface ppp-client print detail
 0  R name="ppp-out1" max-mtu=1500 max-mru=1500 mrru=disabled port=usb1 data-channel=2 info-channel=2 apn="internet" pin="" user="" password=""
      profile=default phone="*99#" dial-command="ATDT" modem-init="ATZ;AT+CFUN=1;ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0" null-modem=no dial-on-demand=no
      add-default-route=no use-peer-dns=yes keepalive-timeout=10 allow=pap,chap,mschap1,mschap2
tested on RB951G - ROS 5.22
Users browsing this forum: No registered users and 106 guests
