Multik
Panasonic behind Mikrotik... SIP
Mon Nov 19, 2012 11:10 am
Hello All...
I have a trouble with setup SIP. Panasonic KX-TD/NCP behind mikrotik...
192.168.28.5,192.168.28.6 -internal IP of Panasonic.
I'm create two dst-nat policy:
0 ;;; ATC
chain=dstnat action=dst-nat to-addresses=192.168.28.5 protocol=udp
dst-address=(external-ip) in-interface=ether1-gateway dst-port=5061
1 ;;; ATC
chain=dstnat action=dst-nat to-addresses=192.168.28.6 protocol=udp
dst-address=(external-ip) in-interface=ether1-gateway dst-port=12000-12511
But voice got to outside only, incoming voice not.
In mikrotik services sip-service is enabled.
coffeecoco
Re: Panasonic behind Mikrotik... SIP
Mon Nov 19, 2012 11:14 am
sip is such a terrible service when mixed with NAT
I see it ALL the time..... life becomes much simple and easy if you create "bridge's" or "VPN's" or Routed networks
Avoid NAT and it all starts to be easy.
NAB
Trainer
Trainer
Mon Nov 19, 2012 12:01 pm
As a VoIP telco, I have to agree. Don't expect it to work. Expect niggles, glitches and strange things. Personally, I am sick to the back teeth of telecoms companies installing systems without having the first clue how the Internet works...
That having been said, there is one thing you can do to make ROS work with SIP better, and that is to disable the SIP ALG which (in my experience) makes things ten times worse. Try:
/ip firewall service-port disable sip
at the command line and see if that improves things.
We place small RouterBoards at our customers' sites and tunnel VoIP traffic over L2TP to our hosted LNS. Removes NAT from the equation completely and also has the advantage that we then have access in to our customers' networks so we can reprogram phones and resolve problems remotely.
But then we're that rare breed of telecoms company - one that knows what it's doing!
Multik
Mon Nov 19, 2012 12:08 pm
I'm tried
IP-Phone/3cxPhone6 can't complete registration on station (Authentication failed)
In packets i see internal IP of Panasonic, i need to change it to external ip
coffeecoco
Mon Nov 19, 2012 12:58 pm
I'm tried
Yes that is the exact problem when you mix SIP with NAT
Expect pain and frustration if you continue to keep trying
save your self time create a tunnel to the remote network
Multik
Mon Nov 19, 2012 1:55 pm
We can't support all 'out-of-office' managers. We want IP-phone usage only.
NAB
Trainer
Trainer
Tue Nov 20, 2012 1:16 pm
The PBX/server they are registering to may be able to flag registrations as from a NATted source. Asterisk, for example, lets you state "nat=yes" in sip.conf in which case the address within the SIP packets is ignored in favour of the source address of the udp IP packet.
If you cannot mark handsets as being from a NATted source, then I am afraid that it simply will not work for you.
I am afraid I do not understand this.
Multik
Tue Nov 20, 2012 1:26 pm
Panasonic dosn't have settings for NAT like Asterisk :(
My be GNU Gatekeeper help me....
Users browsing this forum: Bing [Bot], sindy, Znevna and 125 guests
