americo
Problems with Outlook Service
Fri Feb 10, 2006 2:32 pm
I am trying to Send and Receive from an Outlook Client using Pop3 for receiving and SMTP for sending, but it can't get through my firewalled Router PC. Please, I need some help, I am a beginer. Plz
sergejs
Fri Feb 10, 2006 2:44 pm
you have to give more details about router firewall configuration.
americo
Fri Feb 10, 2006 2:50 pm
ip firewall nat add chain=dstnat src-address=192.168.0.0/24 protocol=tcp dst-prot=80 action=redirect to-ports=8080
cmit
Fri Feb 10, 2006 3:11 pm
well, that's just a rule to allow acces to some internal server from the outside and doesn't help much with your question.
You should at least post your complete firewall config and ip setup...
Best regards,
Christian Meis
Mikro-Man-Tik
Fri Feb 10, 2006 3:20 pm
i think u block some port in your firewall try to use or update your rule like this:
/ ip firewall filter
add chain=input   dst-address=:135-139 protocol=tcp action=drop comment="" disabled=no
add chain=forward dst-address=:137-139 protocol=tcp action=drop comment="" disabled=no
add chain=forward dst-address=:137-139 protocol=udp action=drop comment="" disabled=no
i hope this slove your problem
Regards and good luck...
americo
Fri Feb 10, 2006 3:47 pm
Does anyone knows where can I find a version of RouterPC that doesnt need the Key?????
cmit
Fri Feb 10, 2006 3:58 pm
You don't really want to ask for a c r a c k in an (more or less) official support forum from the manufacturer, do you?
If you do: GO AWAY or purchase a license - it's worth every tenth of a cent you pay for it!
If you meant the 24-hour time-limited demo: Just install the software - it will run for 24 hours without a key...
Best regards,
Christian Meis
americo
Fri Feb 10, 2006 4:20 pm
It is not that. I have heard that version 2.0 of RouterPC, doesnt need a key, is that, but I cant find it. If I cant find it, I will have to purchase a key. Does anyone knows the price?????
Tonda
Fri Feb 10, 2006 4:26 pm
Anybody, who is able to look at Mikrotik web pages.
sergejs
Fri Feb 10, 2006 4:35 pm
all information about licenses and prices are here:
http://www.mikrotik.com/software.php
Users browsing this forum: GoogleOther [Bot], sstefanov and 160 guests
