krakenant
EOIP Tunnel ID
Tue Dec 04, 2012 8:33 pm
Would it be possible to increase the allowable numbers for the tunnel ID above 65,535?
cbrown
Trainer
Trainer
EOIP Tunnel ID
Tue Dec 04, 2012 11:53 pm
Why does it matter? Just curious..
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
krakenant
Re: EOIP Tunnel ID
Thu Dec 06, 2012 10:24 pm
We have a database we keep all of our units in, we use an arbitrary (read sequential) numbering system. We use these arbitrary numbers as reference numbers and as the tunnel ID in reference to the unit. We are nearing the point where any new units won't be able to use existing scripts and EOIP tunnels due to this.
Chupaka
Re: EOIP Tunnel ID
Fri Dec 07, 2012 12:11 pm
I think, there's only 2 bytes in EoIP header for TunnelID, so it's not possible to increase the limit
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
syadnom
Re: EOIP Tunnel ID
Fri Dec 28, 2012 11:29 pm
do not use foreign data as your unique id in your database. id should be it's own thing, usually start at 1 increment by 1, and a different column should store your tunnel id. This way you can set the tunnel id as the lowest available number and recycle ids. also, this is good db design so do it anyway.
Users browsing this forum: No registered users and 116 guests
