tohidianh
KVM Problem
Thu Dec 06, 2012 7:29 am
I install kvm package and i see it on winbox but could not handle it by command line.
please help me how to create a virtual machine using command line
Chupaka
Re: KVM Problem
Thu Dec 06, 2012 10:10 pm
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
vvujasinovic
Re: KVM Problem
Sun Apr 07, 2013 10:51 pm
i have the same problem, KVM menu is visible in winbox, but there is no /kvm menu in console:
[admin@MikroTik] > /kvm
bad command name kvm (line 1 column 2)
[admin@MikroTik] >
What could be the reason for that?
Thanks.
VEki
Chupaka
Re: KVM Problem
Mon Apr 08, 2013 2:28 am
what version of RouterOS do you use?
vvujasinovic
Re: KVM Problem
Mon Apr 08, 2013 2:33 am
Version is 5.24. I have tried even the latest rc of version 6 today with same results...
Regards,
aymen
Re: KVM Problem
Fri Apr 17, 2015 6:32 pm
hi ,
'm using virtual machines (based on QEMU) I wish I have installed Mikrotik x86 (5.20), then I have implement it into my GNS3 platform, all works fine but no KVM within my winobox terminal (bad command line). so I would like to know the cause of this problem to solve it.
Best regards,
Aymen
ZeroByte
Re: KVM Problem
Fri Apr 17, 2015 9:32 pm
qemu does not seem to provide a kvm-compatible CPU.
My GNS3 mikrotiks have the KVM menu, but it's useless to me.
(I may be doing something wrong, but that's what it tells me when I create a kvm host)
When given a spoon,
you should not cling to your fork.
The soup will get cold.
joeyqiao
Re: KVM Problem
Wed Feb 10, 2021 9:03 am
Dear,
I met the same problem like below, and I tried to install the latest stable version (routeros-x86-6.48.1) to vmware workstation, ESXI, Openstack, is there any solutions?
[joey@MikroTik] > /kvm
Chupaka
Re: KVM Problem
Wed Feb 10, 2021 12:52 pm
Did you install kvm package?
/system package print
joeyqiao
Re: KVM Problem
Thu Feb 18, 2021 8:55 am
As you can see, the kvm package was installed, but I'm not able to use the KVM command, and use winbox to add new kvm, it was auto disabled, do you know the reason?
[admin@MikroTik] > /system package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 ppp 6.48
1 system 6.48
2 dhcp 6.48
3 ntp 6.48
4 security 6.48
5 user-manager 6.48
6 advanced-tools 6.48
7 routing 6.48
8 kvm 6.48
[admin@MikroTik] >
[admin@MikroTik] >
Users browsing this forum: leemans, mrthner and 206 guests
