libove
ROS 5.21, DNS false negative?
Thu Dec 13, 2012 7:48 pm
We have a VRRP pair of RouterBOARD 1200, IP addresses 192.168.1.2 and 192.168.1.3, VRRP address 192.168.1.1.
Both are running ROS 5.21. These are our gateway devices to the Internet, in a typical "We're an internal LAN, the MikroTiks let us out to the Internet" medium-sized office configuration. Nothing too special.
We just began having a problem where internal DNS resolution requests - which go to the MikroTiks' VRRP address (192.168.1.1) which is then configured with a list of six possible public DNS servers (two from our upstream ISP, two from Google, and two from OpenDNS) - would return false negatives.
Right at the moment, the VRRP master is 192.168.1.3. The backup (and therefore very un-loaded MikroTik) is 192.168.1.2.
Example:
$ host msgxsignature.domain.net 192.168.1.1
Using domain server:
Address: 192.168.1.1#53
Aliases:
Host msgxsignature.domain.net not found: 3(NXDOMAIN)
$ host msgxsignature.domain.net 192.168.1.2
Address: 192.168.1.2#53
Aliases:
msgxsignature.domain.net is an alias for ec2-5x-1x-6x-22x.compute-1.amazonaws.com.
$ host msgxsignature.domain.net 192.168.1.3
Address: 192.168.1.3#53
Aliases:
So, the VRRP master, which /ip dns cache print shows very full of cached DNS entries, falsely says NXDOMAIN, while the VRRP backup (largely idle) properly looks up and returns the right information.
I did an /ip dns cache flush on the VRRP master, and it began returning the correct DNS lookup results.
Can anyone help me guess whether this is more likely a bug (MikroTik DNS cache gets full, MikroTik DNS server starts behaving badly) or something to do with caching negative responses (although I don't think that's what happened; is there a MikroTik DNS server setting for how long to cache a negative response? For that matter, how can I do an /ip dns cache print where... command to show cached negative responses?
Thanks,
libove
Re: ROS 5.21, DNS false negative?
Tue Dec 18, 2012 6:08 pm
The same problem has just happened again. Once again, it was solved (temporarily) by flushing the cache.
I've now also reduced the cache-max-ttl from the 1w which it had been set at (by default, I guess) to 2d, in hopes that it helps. I'm not confident of that.
This really does look like a bug: When the DNS cache gets "too full" (whatever that might mean; in this case, there were around 3200 entries, using 1976KiB out of cache-size 2048KiB) the MikroTik DNS server starts failing some(?) lookups.
MikroTik, are you listening?
Any suggestions on debugging/ proving what's going on?
Thanks,
-Jay
Users browsing this forum: Anaykh, Crazyn8, mikruser, ZacharyMak and 140 guests
