ThunderBRZ
Problem with UPGRADE to 6rc5
Fri Dec 14, 2012 12:45 am
I have upgrade a rb110x2ah to 6rc5, but after restore a 5.x backup, many changes not works after reboot.
It´s restore a backup state.
normis
Re: Problem with UPGRADE to 6rc5
Fri Dec 14, 2012 12:43 pm
rc5 has some backup issue, try rc6 please:
http://www.mikrotik.com/download/share/ ... 6.0rc6.npk
ThunderBRZ
Sat Dec 15, 2012 1:47 am
Normis... no works... before all, i have downgrade ro 5.22, reset conf, upgrato to 6rc6, but no works restore procedure... nothing restored... in rc5 restore procedure works, but changes after that no works after reboot.
wispwest
Sun Dec 16, 2012 8:38 pm
They fixed the simple queue problem finally, and I reported to support about the problem with it re-naming the interfaces. I assume that will be fixed in rc6, although I haven't seen a changelog and can't risk it until I know that problem is fixed.
That's a major issue!!
Ferrograph
Wed Dec 19, 2012 11:08 am
Im seeing this too and I started a thread specifically for it.
Is it possible there is some command or procedure that will force the config to be saved so that after reboot/power loss the config comes back. I have a site 4hrs drive away and if the power goes the config will go back to one that will leave it inaccessible remotely and a config that wont work for the client - and it took me a long time to talk him into replacing his beloved Draytek with a Mikrotik!
Please help!
Users browsing this forum: Bing [Bot], Google [Bot] and 125 guests
