kwahodi
Can Ping Gateway but NOT computers
Tue Feb 14, 2006 12:53 pm
Hi
I've set up two LAN's approx 4km apart using Integrated router antenna. I can ping the gateway from either LAN's but I cannot ping the computers. Where can I be going wrong? Below are my current settings.
LAN1 -IP address
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.0.1/24 192.168.0.0 192.168.0.255 ether1
1 10.0.0.1/24 10.0.0.0 10.0.0.255 wlan1
IP Route:
DST-ADDRESS PREFSRC G DISTANCE INTERFACE
0 ADC 10.0.0.0/24 10.0.0.1 wlan1
1 ADC 192.168.0.0/24 192.168.0.1 ether1
2 A S 0.0.0.0/0 r 10.0.0.2 wlan1
Interface wireless is set to "p2p"
LAN 2 - IP address
0 192.168.0.2/24 192.168.0.0 192.168.0.255 ether1
1 10.0.0.2/24 10.0.0.0 10.0.0.200 wlan1
IP Route:
0 ADC 10.0.0.0/24 10.0.0.2 wlan1
1 ADC 192.168.0.0/24 192.168.0.2 ether1
2 A S 0.0.0.0/0 r 10.0.0.1 wlan1
Borage
Tue Feb 14, 2006 3:06 pm
What is the computers default gateway? If all computers default gateway is something else than the Mikrotik routers IP address, then you have to add a static route in those gateways to point to each Mikrotik routers IP address on the LAN interface. Another thing is that you cannot use the same subnet on both LAN i.e. 192.168.0.0/24. For example, use 192.168.0.0/24 on one side and 192.168.1.0/24 on the other side
raulborda
Re: Can Ping Gateway but NOT computers
Tue Feb 14, 2006 11:13 pm
Hi
LAN1 -IP address
IP Route:
LAN 2 - IP address
IP Route:
If net setup is correct.
What is the computer's S.O.???
Borage
Tue Feb 14, 2006 11:53 pm
The net setup is not correct, unless he are intended to bridge between those both sites, and if that is the case, then he should only assign an IP address to the bridge interface and the default gateway to each other is not necessary.
Users browsing this forum: No registered users and 169 guests
