ulven
USB issues on 2011UAS-2HnD
Mon Dec 17, 2012 1:09 am
I have a small problem with my 2011UAS-2HnD and USB 3G Modems.
The USB port and device is not visible anywhere, although the USB modem receives power and is "blinking as normal".
I've also tried connecting an USB thumb drive, with the same result.
The modem works great on my old RB751G-2HnD, so i know the modem is working as it should.
Below is some info that might be relevant.
ros code
[admin@MikroTik] > system routerboard print
       routerboard: yes
             model: 2011UAS-2HnD
     serial-number: 3F0602863E08
  current-firmware: 3.02
  upgrade-firmware: 3.02
[admin@MikroTik] > system resource print
                   uptime: 18m28s
                  version: 6.0rc5
              free-memory: 109572KiB
             total-memory: 126852KiB
                      cpu: MIPS 74Kc V4.12
                cpu-count: 1
            cpu-frequency: 600MHz
                 cpu-load: 2%
           free-hdd-space: 112676KiB
          total-hdd-space: 126976KiB
  write-sect-since-reboot: 74
         write-sect-total: 47509
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: RB2011UAS-2HnD
                 platform: MikroTik
[admin@MikroTik] > system package print
Flags: X - disabled
 #   NAME                    VERSION                    SCHEDULED
 0   routeros-mipsbe         6.0rc5
 1   system                  6.0rc5
 2 X routing                 6.0rc5
 3   ntp                     6.0rc5
 4   security                6.0rc5
 5   dhcp                    6.0rc5
 6   advanced-tools          6.0rc5
 7   wireless                6.0rc5
 8   ppp                     6.0rc5
 9   hotspot                 6.0rc5
[admin@MikroTik] > system resource usb print
 # DEVICE VENDOR                   NAME                  SPEED
 0 1:1    Linux 3.3.5 ehci_hcd     RB400 EHCI            480 Mbps
[admin@MikroTik] > port print
Flags: I - inactive
 #   NAME                        CHANNELS USED-BY                     BAUD-RATE
 0   serial0                            1 Serial Console              auto
[admin@MikroTik] >
Does anyone have any suggestions?
Dobby
Re: USB issues on 2011UAS-2HnD
Mon Dec 17, 2012 8:30 am
Hello ulven,
can it perhaps be, that the USB port is not powered at the RB2011 series?
normis
Mon Dec 17, 2012 8:38 am
Hello ulven,
It is powered, but as the RB2011 has a microUSB connector, you must use an OTG cable to use it. Some cables are not OTG, so must check if yours is.
ulven
Mon Dec 17, 2012 12:33 pm
I've tried three different cables, including the original OTG cable for my Samsung Galaxy S2.
All with the same issue.
ulven
Wed Dec 19, 2012 10:12 pm
So, no one has any ideas?
How about some suggestions on how I can troubleshoot the hardware to determine if there is something wrong with the USB port?
normis
Wed Dec 19, 2012 10:45 pm
We have found a potential issue on this device, it will be addressed in a software update. The issue causes some specific devices not to be recognised.
Dobby
Thu Dec 20, 2012 10:22 am
Hello ulven,
did you try out the following?
Please connect the USB modem to the USB port and then reboot
the RouterBoard and watch out once more again if you can see the modem now.
ulven
Thu Dec 27, 2012 1:43 pm
Not to be rude but;
Yes, (of course) I tried that, and it still does not work, but thanks for the suggestion anyway.
I've also updated the software to v6.0rc6 since last time, but still no luck.
uldis
Thu Dec 27, 2012 1:52 pm
another suggestion is to connect the USB device, remove the power for the board and power the board up again - most of the times it helps.
Dobby
Thu Dec 27, 2012 2:18 pm
Hello ulven,
Not to be rude but;
I have seen this, given as an answer in one other forum thread and it was helping another user with similar the same problem! I want not kidding you.
ulven
Fri Dec 28, 2012 2:15 am
Finally i got it working.
It was uldis's solution that finally did the trick, although I've tried it before without success.
And another apology to Dobby for being a bit rude.
I was just in a bad mood, and should probably have waited a bit before posting.
Thanks to everyone for their replies.
w0lt
Fri Dec 28, 2012 2:40 am
I was having the exact same issue with my RB2011UAS-RM, and Uldis trick worked for me as well. I look forward to this little bug being squashed real soon.
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
kgninfos
Tue Jan 01, 2013 5:46 pm
usb power reset works fine in v 5.22
also set
/system routerboard usb
to
mode:force-host
then it will detect the data cards
odge
Tue Feb 26, 2013 11:32 pm
on 5.21 I could see my modem in list of USB devices.
upgrade to 5.22, and restart as per suggestion, and I get a ppp interface showing.
However, i cannot do scans etc or connect, I always get "couldn't aquire port"
the same modem works on a 751.
Any suggestions
Regards
odge
Tue Feb 26, 2013 11:39 pm
Any suggestions
Regards
Uh... and then, repeating the same steps, again this time (i used reset a few times), and its working...
odge
Wed Feb 27, 2013 3:25 pm
Well, I'm not having much success actually.
The 3G seems to lose its signal and disconnect, and also seems to drop most pings, but this same stick has no problem in the same office with a 751.
Could it be a power issue on the RB2011
Dobby
Sun Mar 10, 2013 3:36 am
I was thinking at first also, but the USB port is really powered and you only need a OTG cable thats it.
Users browsing this forum: No registered users and 31 guests
