Nekromans
dont work DHCP on vlan interface
Wed Dec 26, 2012 11:44 pm
grg
Re: dont work DHCP on vlan interface
Thu Dec 27, 2012 10:38 am
I had the same issue this morning on my CCR1036-12G-4S with ROS v6.0rc6. DHCP service stopped issuing IP addresses on all VLAN interfaces. I had to tinker around with it until I got it to work again. I think disabling and re-enabling DHCP servers fixed it, but I'm not completely sure about it. MikroTik, please look into this problem.
janisk
Thu Dec 27, 2012 1:00 pm
is there any idea how to cause this?
grg
Thu Dec 27, 2012 2:07 pm
In my case it took time for it to stop responding. Two or three days, maybe. It's a network with around 50 clients.
This is my interface configuration:
add name=bridge_local
add l2mtu=1590 name=bridge_internet
/interface vlan
add interface=bridge_local l2mtu=65531 name=vlan101 vlan-id=101
add interface=bridge_local l2mtu=65531 name=vlan102 vlan-id=102
add interface=bridge_local l2mtu=65531 name=vlan103 vlan-id=103
add interface=bridge_local l2mtu=65531 name=vlan104 vlan-id=104
add interface=bridge_local l2mtu=65531 name=vlan105 vlan-id=105
add interface=bridge_local l2mtu=65531 name=vlan106 vlan-id=106
add interface=bridge_local l2mtu=65531 name=vlan107 vlan-id=107
add interface=bridge_local l2mtu=65531 name=vlan108 vlan-id=108
add interface=bridge_local l2mtu=65531 name=vlan109 vlan-id=109
add interface=bridge_local l2mtu=65531 name=vlan110 vlan-id=110
add interface=bridge_local l2mtu=65531 name=vlan111 vlan-id=111
/interface bonding
add link-monitoring=none mode=802.3ad name=bonding_local slaves=ether11,ether10,ether9,ether8
add bridge=bridge_local interface=bonding_local
add bridge=bridge_internet interface=ether1
Every VLAN interface has it's own DHCP server instance assigned to it.
initd
Sun Jan 06, 2013 9:24 pm
Acknowledge there is a problem with dhcp CLIENT! on vlan interface does not receive mail after reboot.
receives the address after:
/ip dhcp-client disable 0
/ip dhcp-client enable 0
751G, 6.0rc6
janisk
Mon Jan 07, 2013 12:09 pm
does it do the same after reboot? also, was dhcp-client enabled, as per default new dhcp-client is disabled when added.
initd
Mon Jan 07, 2013 1:45 pm
I was told by e-mail
"Hello,
Thank you for reporting, problem is reproduced and will be fixed in the next
RouterOS release."
reboot constantly writing: "searching..."
Users browsing this forum: Florian, MSN [Bot], reman6110 and 59 guests
