MUM Europe 2020
popcorrin
2 routers at my core
Fri Jan 04, 2013 5:26 pm
I currently have 1 router at my core fed from one provider. I'm thinking of running 2 routers at my core fed from 2 separate providers for redundancy and higher capacity.
I'm looking for opinions on this and was wondering if anyone could offer some advice on the best way to go about setting this up.
cbrown
Trainer
Trainer
Re: 2 routers at my core
Fri Jan 04, 2013 8:04 pm
Are you wanting to run a provider to each router or both providers to both routers?
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
popcorrin
Fri Jan 04, 2013 8:31 pm
A provider to each router I suppose is the only way since I'm pretty sure they each will only give me a single circuit.
jaduke
Fri Jan 04, 2013 8:51 pm
If you setup the routers with VRRP (aka failover), you can place a switch (can be a single switch) in between your provider's handoff (from cable or DSL modem e.g. ethernet) and each router. When router A fails, router B just simply picks up (via VRRP) and keeps everything humming.
Read the documentation for more detail, but I've done a setup like this (not with RouterOS) and it worked well.
If you have any more questions regarding VRRP, let me know.
Thanks.
Cheers,
Jon
popcorrin
Sat Jan 05, 2013 8:30 am
Thanks.
Cheers,
Jon
Seems like that would be just adding another point of failure?
Users browsing this forum: Bing [Bot], dalami and 71 guests
