cylent
Recommendation for a home wifi system (a/n and b/g/n)
Sun Jan 13, 2013 9:56 pm
I need to setup wifi at a house thats actually more of an office. every room is an office... somewhat.
so signal is literally very important.
I wanted to have dual radios (a/n and b/g/n) in a few routerboards ... the only one that looks/is easy to setup is the rb2011-wifi but thats only 2.4 and i need 5Ghz also.
Can anyone advise on how to achieve this with what hardware?
samsung172
Re: Recommendation for a home wifi system (a/n and b/g/n)
Sun Jan 13, 2013 10:49 pm
To use both 2,4 and 5ghz, you'll ned a setup With 2 wlan Cards. No standard system from MT have this. You need a Board, and add another card.
Try http://routerboard.com/RB411UAHR as one possibility. and put it to a http://routerboard.com/CA411-711 and have a cheep abgn card to it.
Ivoshiee
Sun Jan 13, 2013 11:17 pm
If the 2.4GHz n is not really needed then the RB411AR should do the trick with added R52nM (or R52) for 5 GHz operations. Why the need for an GSM model, which is more expensive and that functionality is not needed anyway?
http://routerboard.com/RB411AR
samsung172
Mon Jan 14, 2013 8:45 pm
I Just answered the Question. witch was a/n - b/g/n
There is a lot of cheep hardware that is possible to use.
Ivoshiee
Mon Jan 14, 2013 9:04 pm
The RB411UAHR does not have b,g,n either, so why to recommend that?
Users browsing this forum: No registered users and 122 guests
