jackwisp
Queue Problems in RB1100AHx2 (SMP)
Tue Jan 15, 2013 4:38 am
Hello, I'm using an RB1200 very happy for the last year as my border router, I'm running several mangle rules and a large and very beatifull queue tree to priorize some services.
All works great, queue tree and mangle rules based on QoS and protocols works great.
Due to traffic growing, we decided to switch to a more powerfull router (~80% CPU usage in my old RB1200), here decided to migrate our border router to a new dual ppc RB1100AHx2 borad.
After migrating problems begins, the first I see is a heavy traffic drop, and then I see about 20~30% packet loss when I try to go trought this new router.
Severals try & error tests show me that if I disable the whole queue tree Packet loss drop to 0% and traffic grow up to the normal levels, ( of course I need queue tree to priorize traffic. ).
I see some issues with differents queue type when the platform is SMP, I tryed with all queue types and with all I have problems.
I see peoples having different problems with this router (RB1100AHx2) but not exactly what I have.
I'm using two ports of the router, ETH1 is my upstream and ETH6 is the downstream interface.
Any ideas ?
Beast Regards,
Jack.-
lambert
Long time Member
Long time Member
Re: Queue Problems in RB1100AHx2 (SMP)
Tue Jan 15, 2013 7:20 am
What version of RouterOS was on the RB1200?
What version of RouterOS is on the RB1100AHx2?
Are there any unexpected entries in the logs?
My RB1100AHx2 with RouterOS 5.21 began rebooting at random intervals when I pushed traffic through port Ether2. I don't know if the port was important or just the switch group or if it was unrelated... MikroTik support gave me 6.0rc6. That ran good with traffic on port Ether2. Then I enabled my QoS queue tree again. Reboots. So MikroTik support gave me 6.0rc7. That is working with queue tree.
So, what I'm trying to say is, you may need 6.0rc7 or newer to make the RB1100AHx2 behave.
I wish not. I don't like running production hardware on alpha level software. But when the alpha level software works better than released software, you do what you have to do. I am encouraged by the rapidity with which MikroTik support responded to my problem reports.
jackwisp
Wed Jan 16, 2013 4:37 pm
Unhappy with the change, We decided to roll back to the RB1200 Router.
RB1100AHx2 don't work, packet loss when queue tree enabled.
We're very unhappy with this hardware and we can't find any response from mkt (we have tested diferents RB1100AHx2).
husamaga
Wed Jan 16, 2013 5:03 pm
i have the same problem with rb1100ahx2, so when i removed the queue the router started to work better, but have a lot of lost packages.
JJCinAZ
Wed Jan 16, 2013 5:09 pm
We see the same thing. There is clearly a problem after 5.6 (v6 also has the issue). You can install 5.6 to clear up the packet loss in my testing. I submitted a bug report with exacting reproduction steps back on dec 18th. Got initial run-around but maybe they are starting to look more closely. You should build your own support ticket to get it more attention.
Joe
husamaga
Wed Jan 16, 2013 5:29 pm
doe's version 5.6 works with rb1100ahx2? for sure?
csohns
Thu Jan 17, 2013 2:09 am
5.22 here-- Put a new 1100AHx2 into production yesterday, discovered the hard way this morning that my queue trees were utterly obliterating VoIP audio quality. Good(?) to see I'm not the only one.
husamaga
Thu Jan 17, 2013 9:11 am
When you made a queue on the RB, try to ping the router from the terminal (to ping your self) the ping goes over 30ms :)
what a stupid system..
lambert
Long time Member
Long time Member
Thu Jan 17, 2013 11:24 pm
I am unable to replicate your reported issues on 6.0rc7.
[lambert@RB1100AHx2_6.0rc7] > /queue tree print count
154
[lambert@RB1100AHx2_6.0rc7] > /ip addr print
 #   ADDRESS            NETWORK         INTERFACE
 3   10.128.1.13/29     10.128.1.8      vlan11
 4   10.128.1.5/29      10.128.1.0      vlan13
 5   10.128.80.5/29     10.128.80.0     vlan12
[lambert@RB1100AHx2_6.0rc7] > ping 10.128.1.13
HOST                                     SIZE TTL TIME  STATUS
10.128.1.13                                56  64 0ms
    sent=10 received=10 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
Locally connected BSD box to RB1100AHx2_6.0rc7
15:16:23 Thu Jan 17 $ sudo ping -i0.01 -s1400 -c1000 -q 10.128.1.13
PING 10.128.1.13 (10.128.1.13): 1400 data bytes
--- 10.128.1.13 ping statistics ---
1000 packets transmitted, 998 packets received, 0% packet loss
round-trip min/avg/max/stddev = 0.221/0.784/13.093/1.145 ms
Same BSD box to RB493G on other side of RB1100AHx2_6.0rc7 (via 2km RocketM5 link between the 1100 and the 493).
15:18:17 Thu Jan 17 $ sudo ping -i0.01 -s1400 -c1000 -q 10.128.1.12
PING 10.128.1.12 (10.128.1.12): 1400 data bytes
--- 10.128.1.12 ping statistics ---
1000 packets transmitted, 996 packets received, 0% packet loss
round-trip min/avg/max/stddev = 1.140/1.745/18.715/1.360 ms
longerCZ
Thu Sep 05, 2013 11:32 am
Hi, we had the same issue here and we solved it by setting all interface-queues to "only-hardware-queue".
jirif
Thu Oct 24, 2013 9:19 am
Random packetloss up to 10%, not working queue tree.
I had those issues with queue tree (300+ rules per interface, 2 interfaces) attached directly to ethernet interface (this setup in fact replacing interface-queue). Then i reworked qos to use global queue and the problems disapeared :D
It look like ethernet driver bug,
using RB1100AHX2@ROS 6.4.
Zod
Fri Nov 29, 2013 3:43 pm
I did not find this entry when I was searching for this problem and started another on the same topic. http://forum.mikrotik.com/viewtopic.php?f=2&t=79282
I've tried the two ideas on changing the queue type and they did Not help. Using Simple queues greatly restricts the functionality of the device and is not 'really' a solution.
This problem can be reproduced on the bench 100% of the time IMHO. I've opened a ticket with support but have not heard back on it yet.
This is a pretty big issue for the 1100AHx2. Any other ideas greatly appreciated.
Users browsing this forum: Google [Bot], MSN [Bot] and 159 guests
