tikkie
Host ip keeps changing. Multiple logins.
Sun Feb 19, 2006 11:32 pm
Hi:
We have been having problems like this since the upgrade from 2.8 to 2.9. This only seems to happen for a select few users on the hotspot. We contacted the users and ran virus checks on their pc's with nothing found. We also verified they use dhcp on the router or pc. We thought the trouble might be with radius so we made them local users and the problem is still there. In a nutshell, when a new host is detected for the problem users we see:
new host detected 00:0F:66:20:44:0E/216.143.130.36
Where the IP address changes all the time. They are using dhcp so we don't know where these strange ip's are coming from. Sometime they are from our lan pool and other times they are real ip's. It seems that the login mechanism is not waiting to login the user before it makes a second attempt to log them in again. This makes the first attempt fail and the next attempt is seen as a new host with a new ip. This could take 10 cycles sometime and other times it can take 100 or 200 or more before all the old attempts time out and the new one takes hold. This does not seem to be a dhcp issue because even if they are statically assigned we still see the problem. I've seen only a few people post that they are having the same issues and no one has answered them.
So, how does the hotspot login mechanism work? When it sees a new mac on the network it's supposed to check the user list and let them in if they are there. What would trigger the hotspot to send a user to the login mechanism multiple times without waiting for the first time to pass or fail. If the pc pushes through 100 unauthorized packets does it view each one as a login attempt and send it for auth? Is there a way to stop this? Does this seem like it could be what's happening or does anyone have any other ideas? Here is what the logs look like for one of these users. Any help would be appreciated.
Thanks,
Larry
14:58:46 hotspot,debug hs-ether4-Hotspot network: new host detected 00:0F:66:20:44:0E/216.143.130.36
14:58:46 hotspot,info,debug 00:0F:66:20:44:0E (10.5.50.253): logged out: host removed
14:58:46 hotspot,account 00:0F:66:20:44:0E (10.5.50.253): 3492 253424 9569101 4980 6691 (host removed)
14:58:46 hotspot,debug 00:0F:66:20:44:0E (10.5.50.253): removing queue
14:58:46 hotspot,debug 00:0F:66:20:44:0E (10.5.50.253): removing ip->user binding
14:58:46 hotspot,debug hs-ether4-Hotspot network: dhcp host 10.5.50.253 removed: limiting addresses per mac
14:58:46 hotspot,info,debug 00:0F:66:20:44:0E (10.5.50.45): trying to log in by mac
14:58:46 hotspot,debug 00:0F:66:20:44:0E (10.5.50.45): using profile <nokeepalive>
14:58:46 hotspot,debug 00:0F:66:20:44:0E (10.5.50.45): adding ip->user binding
14:58:46 hotspot,debug hs-ether4-Hotspot network: dynamic host 00:0F:66:20:44:0E/216.143.130.36 added, ip 10.5.50.45
14:58:46 hotspot,debug 00:0F:66:20:44:0E (10.5.50.45): adding queue <192k/1280k>
14:58:46 hotspot,account,info,debug 00:0F:66:20:44:0E (10.5.50.45): logged in
14:58:56 hotspot,debug hs-ether4-Hotspot network: new host detected 00:0F:66:20:44:0E/10.5.50.253
14:58:56 hotspot,info,debug 00:0F:66:20:44:0E (10.5.50.45): logged out: host removed
14:58:56 hotspot,account 00:0F:66:20:44:0E (10.5.50.45): 11 0 0 0 0 (host removed)
14:58:56 hotspot,debug 00:0F:66:20:44:0E (10.5.50.45): removing queue
14:58:56 hotspot,debug 00:0F:66:20:44:0E (10.5.50.45): removing ip->user binding
14:58:56 hotspot,debug hs-ether4-Hotspot network: dynamic host 10.5.50.45 removed: limiting addresses per mac
14:58:56 hotspot,info,debug 00:0F:66:20:44:0E (10.5.50.253): trying to log in by mac
14:58:56 hotspot,debug 00:0F:66:20:44:0E (10.5.50.253): using profile <nokeepalive>
14:58:56 hotspot,debug 00:0F:66:20:44:0E (10.5.50.253): adding ip->user binding
14:58:56 hotspot,debug hs-ether4-Hotspot network: dhcp host 00:0F:66:20:44:0E/10.5.50.253 added, ip 10.5.50.253
14:58:56 hotspot,debug 00:0F:66:20:44:0E (10.5.50.253): adding queue <192k/1280k>
14:58:56 hotspot,account,info,debug 00:0F:66:20:44:0E (10.5.50.253): logged in
15:00:46 hotspot,debug hs-ether4-Hotspot network: new host detected 00:0F:66:20:44:0E/216.143.130.36
15:00:46 hotspot,info,debug 00:0F:66:20:44:0E (10.5.50.253): logged out: host removed
15:00:46 hotspot,account 00:0F:66:20:44:0E (10.5.50.253): 110 1734 0 18 0 (host removed)
15:00:46 hotspot,debug 00:0F:66:20:44:0E (10.5.50.253): removing queue
15:00:46 hotspot,debug 00:0F:66:20:44:0E (10.5.50.253): removing ip->user binding
15:00:46 hotspot,debug hs-ether4-Hotspot network: dhcp host 10.5.50.253 removed: limiting addresses per mac
15:00:46 hotspot,info,debug 00:0F:66:20:44:0E (10.5.50.45): trying to log in by mac
15:00:46 hotspot,debug 00:0F:66:20:44:0E (10.5.50.45): using profile <nokeepalive>
15:00:46 hotspot,debug 00:0F:66:20:44:0E (10.5.50.45): adding ip->user binding
15:00:46 hotspot,debug hs-ether4-Hotspot network: dynamic host 00:0F:66:20:44:0E/216.143.130.36 added, ip 10.5.50.45
15:00:46 hotspot,debug 00:0F:66:20:44:0E (10.5.50.45): adding queue <192k/1280k>
15:00:46 hotspot,account,info,debug 00:0F:66:20:44:0E (10.5.50.45): logged in
15:00:52 hotspot,debug hs-ether4-Hotspot network: new host detected 00:0F:66:20:44:0E/10.5.50.253
15:00:52 hotspot,info,debug 00:0F:66:20:44:0E (10.5.50.45): logged out: host removed
15:00:52 hotspot,account 00:0F:66:20:44:0E (10.5.50.45): 5 0 0 0 0 (host removed)
15:00:52 hotspot,debug 00:0F:66:20:44:0E (10.5.50.45): removing queue
15:00:52 hotspot,debug 00:0F:66:20:44:0E (10.5.50.45): removing ip->user binding
15:00:52 hotspot,debug hs-ether4-Hotspot network: dynamic host 10.5.50.45 removed: limiting addresses per mac
15:00:52 hotspot,info,debug 00:0F:66:20:44:0E (10.5.50.253): trying to log in by mac
15:00:52 hotspot,debug 00:0F:66:20:44:0E (10.5.50.253): using profile <nokeepalive>
15:00:52 hotspot,debug 00:0F:66:20:44:0E (10.5.50.253): adding ip->user binding
15:00:52 hotspot,debug hs-ether4-Hotspot network: dhcp host 00:0F:66:20:44:0E/10.5.50.253 added, ip 10.5.50.253
15:00:52 hotspot,debug 00:0F:66:20:44:0E (10.5.50.253): adding queue <192k/1280k>
15:00:52 hotspot,account,info,debug 00:0F:66:20:44:0E (10.5.50.253): logged in
15:02:47 hotspot,debug hs-ether4-Hotspot network: new host detected 00:0F:66:20:44:0E/216.143.130.36
15:02:47 hotspot,info,debug 00:0F:66:20:44:0E (10.5.50.253): logged out: host removed
15:02:47 hotspot,account 00:0F:66:20:44:0E (10.5.50.253): 115 2176 1048 24 11 (host removed)
15:02:47 hotspot,debug 00:0F:66:20:44:0E (10.5.50.253): removing queue
15:02:47 hotspot,debug 00:0F:66:20:44:0E (10.5.50.253): removing ip->user binding
15:02:47 hotspot,debug hs-ether4-Hotspot network: dhcp host 10.5.50.253 removed: limiting addresses per mac
15:02:47 hotspot,info,debug 00:0F:66:20:44:0E (10.5.50.45): trying to log in by mac
15:02:47 hotspot,debug 00:0F:66:20:44:0E (10.5.50.45): using profile <nokeepalive>
15:02:47 hotspot,debug 00:0F:66:20:44:0E (10.5.50.45): adding ip->user binding
15:02:47 hotspot,debug hs-ether4-Hotspot network: dynamic host 00:0F:66:20:44:0E/216.143.130.36 added, ip 10.5.50.45
15:02:47 hotspot,debug 00:0F:66:20:44:0E (10.5.50.45): adding queue <192k/1280k>
15:02:47 hotspot,account,info,debug 00:0F:66:20:44:0E (10.5.50.45): logged in
sublimespot
Thu Feb 23, 2006 1:28 am
I also experience this where the IP number for a hotspot user keeps changing. Its driving me nuts
normis
Fri Feb 24, 2006 3:59 pm
Quick workaround: set addresses-per-mac=2 for hotspot server.
Hotspot detects two IP addresses behind the same MAC address. If allowed
addresses-per-mac=1, then old host entry is replaced by new one. If hotspot
receives packets from both IP addresses with the same MAC all the time, then
hotspot keeps switching between those two IP addresses all the time.
Use sniffer tool to find out more. Check for IP packets coming from
<wrong-ip>. If there is none, check ARP packets containing <wrong-ip>. There
should be something with that IP. Find source of those packets.
tikkie
Follow up on Host ip keeps changing. Multiple logins.
Tue Feb 28, 2006 1:14 am
Hi Normis:
Thanks so much for your suggestion. I have done what you suggested in the past "set addresses-per-mac=2 for hotspot server." and also set it that way again now. The same 4 users are still causing problems but now with the change you suggested it does things a bit differently. Before they would be logged off and then logged back on over and over again. This would trigger the message:
Now with the setting as you suggested we still have the same thing happening except the user is not logged off and then back on. Now the message states:
Login failed: no more sessions are allowed for user
At least the user stays logged in now but the constant detecting of a new host is still triggering many login attempts, huge amounts of log entries and hundreds of hits to our radius server. As a result I changed them over to local user auth so at least they don't use the bandwidth and bomb the radius server.
As per your other suggestion, I am using the sniffer tool in the hopes of tracking down just what these 4 users are doing that is causing us these problems.
Thanks again for taking the time to reply.
Larry
milance
Tue Mar 07, 2006 12:59 am
I also have that problem... I upgrade my MT 2.8.x on 2.9.14 .... And after 3 days I backup my old MT... What was the problem -> I will explain my configuration shortly and some problems ->
I'm using cisco router for controling public traffic
I'm using Mikrtoik for home users (private addresses) and to control the speed of Public addresses (via queue)
I have 3 LAN ports on MT
LAN 1 > outgoing interface (connected on cisco router)
LAN 2 > incoming interface for users with private addresses (they going out thrue LAN 1 like one public address)
LAN 3 > incoming interface for users with public addresses (they going out thrue LAN 1 like they are)
All traffic come in one switch and going in MT with two cables in LAN2 and LAN3
In version 2.8.28 everything works good.... but in 2.9.14 I have next problems:
1. Half of public addresses doesn't want to work ??!!?? Hotspot takes them in hosts and translate them in private addresses witch don't want to work !!!!
2. some of users with private addresses have <host remove>
I make firewall rules witch reject all trafic of public addresses on LAN2 and all traffic from private addresses on LAN3.... But in arp table I can see some (few) of private addresses, and also in hotspot/hosts I can see some of public addresses.....
Why I put hotspot server and all that on LAN2 if that works and with LAN3 ..
I think that the problem is in Automaticly given Firewall Rules, but I don't know how to change them. I try to erase some of them but after reboot they comeback.... I think that becouse in that rules is in the begin jump rule for all interfaces for all addresses......
If somebody understand me and my problem it's will be nice to see some answer.....
P.S. Sorry on my bad english
kevinoct
Tue Mar 21, 2006 6:17 am
We are having exactly the same issue using MAC authentication. We have tried every software version from 2.9.1 through 2.9.17 to no avail. We have also tried setting 2 addresses per MAC and other suggestions posted here in without success. In some cases we have had to bypass hotspot or disable it.
But that is not all. Sometimes our radius server would crash and we would have to reboot it. We have not been able to find the problem until today when we saw a customer trying to log in so rapidly and frequently with the same MAC address that it caused a denial of service attack on our radius server.
Note: Our radius server is a Dell 2650 with dual processors and raid hard drives so it can take a lot of abuse.
I think this is a bug that needs to be addressed as soon as possible.
tikkie
RE: Host ip keeps changing. Multiple logins
Tue Mar 21, 2006 6:31 am
Hi:
Glad and sorry to see others are having this problem as well. We had to upgrade to 2.9 because of this damn problem. 2.9 stopped our winbox from crashing all the time but the problem is still here. Some of the problems were fixed by upgrading firmware in customers routers. Other times we were able to fix it by resetting the customers routers to factory defaults. Some don't get fixed no matter what we do. I currently have a guy blocked and we still have 300 mac/ip changes an hour coming from him. I'll shut him off at the switch in a few days because we just can't have this on the network. You might want to set these users to local auth instead of radius. At least that will stop them from taking your radius server down like they did to us.
The problem does not seem specific to any specific manufacturer or hardware. We scanned customers equipment for viruses and such but nothing is found. In some cases the customer only has a router connected to us with nothing plugged into their routers lan. The problem still happens.
I guess when this thread fills up more with complaints then this will be looked at more closely and hopefully fixed.
Larry
normis
Tue Mar 21, 2006 10:56 am
Please someone with <host remove> problem (with Addresses-per-mac=2) create
supout file when it happens. And send it to support. We cannot reproduce the
problem, when addresses-per-mac=2.
Another solution: block wrong ip/mac pairs with blocked ip-binding entries.
Can someone offer better solution?
It is possible to limit how frequently it is allowed to change ip for mac
address. Lets say to 3s. But it will create another problem - during those 3s
when wrong ip will be set, client will not be able to communicate at all!
Is there some way how Hotspot can distinguish the right ip from the wrong?
What are those packets, which come from wrong ip? Maybe hotspot can ignore
those... Has someone sniffed the ethernet frames, which contain that wrong
IP? Please send them to support.
chris-oct
Tue Mar 21, 2006 8:34 pm
Here is a situation we had this morning. Notice the MAC address ending in "7A". It tries to log into hotspot with 20 different IP numbers. They are all fighting to log in. Each request hits the radius server and ended up DoS our radius server:
hotspot,info,debug XX.XX:BF:82:0F:7A (204.16.208.104): trying to log in by mac in 21-Mar 10:8:55.39 from xxx.xxx.199.22
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:8:55.47 from xxx.xxx.199.22
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:8:55.48 from xxx.xxx.199.22
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.199.22): trying to log in by mac in 21-Mar 10:8:58.37 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:8:58.42 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:8:58.42 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.195): trying to log in by mac in 21-Mar 10:8:58.42 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:8:58.45 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:8:58.53 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (68.42.192.11): trying to log in by mac in 21-Mar 10:8:58.53 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (65.27.174.145): trying to log in by mac in 21-Mar 10:8:58.53 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (218.255.42.4): trying to log in by mac in 21-Mar 10:8:58.53 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (213.184.222.38): trying to log in by mac in 21-Mar 10:8:58.53 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (62.205.90.208): trying to log in by mac in 21-Mar 10:8:58.53 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (82.7.119.23): trying to log in by mac in 21-Mar 10:8:58.53 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (70.94.50.46): trying to log in by mac in 21-Mar 10:8:58.53 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (67.141.250.200): trying to log in by mac in 21-Mar 10:8:58.53 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (84.102.57.124): trying to log in by mac in 21-Mar 10:8:58.56 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (24.60.108.20): trying to log in by mac in 21-Mar 10:8:58.56 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (69.128.156.67): trying to log in by mac in 21-Mar 10:8:58.56 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:8:58.57 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:8:58.62 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:8:58.62 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:8:58.67 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:8:58.68 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:8:58.73 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (80.100.155.83): trying to log in by mac in 21-Mar 10:8:58.75 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (67.140.33.84): trying to log in by mac in 21-Mar 10:8:58.75 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (72.228.28.111): trying to log in by mac in 21-Mar 10:8:58.75 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (12.205.149.63): trying to log in by mac in 21-Mar 10:8:58.75 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (217.83.52.142): trying to log in by mac in 21-Mar 10:8:58.75 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (216.250.59.138): trying to log in by mac in 21-Mar 10:8:58.75 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (81.68.234.174): trying to log in by mac in 21-Mar 10:8:58.75 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (65.190.85.108): trying to log in by mac in 21-Mar 10:8:58.76 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (166.82.173.96): trying to log in by mac in 21-Mar 10:8:58.76 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (71.12.188.249): trying to log in by mac in 21-Mar 10:8:58.76 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (81.71.11.31): trying to log in by mac in 21-Mar 10:8:58.76 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (24.42.116.223): trying to log in by mac in 21-Mar 10:8:58.76 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (213.219.75.38): trying to log in by mac in 21-Mar 10:8:58.76 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (68.90.224.212): trying to log in by mac in 21-Mar 10:8:58.78 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:8:58.81 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:8:58.84 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (166.82.153.143): trying to log in by mac in 21-Mar 10:8:58.86 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (69.208.87.150): trying to log in by mac in 21-Mar 10:8:58.86 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (86.81.197.47): trying to log in by mac in 21-Mar 10:8:58.87 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:8:58.90 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:8:58.95 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:8:58.95 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:8:58.98 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (85.98.33.230): trying to log in by mac in 21-Mar 10:8:59.0 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (139.78.228.158): trying to log in by mac in 21-Mar 10:8:59.0 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:8:59.3 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:8:59.7 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (69.148.185.28): trying to log in by mac in 21-Mar 10:8:59.7 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (142.68.120.141): trying to log in by mac in 21-Mar 10:8:59.7 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (172.143.76.117): trying to log in by mac in 21-Mar 10:8:59.9 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (207.192.253.50): trying to log in by mac in 21-Mar 10:8:59.12 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (69.166.66.251): trying to log in by mac in 21-Mar 10:8:59.31 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:8:59.34 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:8:59.37 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (70.246.134.159): trying to log in by mac in 21-Mar 10:8:59.40 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (65.27.174.145): login failed: RADIUS server is not responding in 21-Mar 10:8:59.40 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (62.205.90.208): login failed: RADIUS server is not responding in 21-Mar 10:8:59.40 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:8:59.40 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (24.60.108.20): login failed: RADIUS server is not responding in 21-Mar 10:8:59.46 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (67.141.250.200): login failed: RADIUS server is not responding in 21-Mar 10:8:59.46 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (84.102.57.124): login failed: RADIUS server is not responding in 21-Mar 10:8:59.46 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (70.243.37.185): trying to log in by mac in 21-Mar 10:8:59.51 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:8:59.51 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:8:59.56 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (70.94.50.46): trying to log in by mac in 21-Mar 10:8:59.57 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:8:59.61 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:8:59.64 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (209.160.72.123): trying to log in by mac in 21-Mar 10:8:59.65 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (70.17.19.193): trying to log in by mac in 21-Mar 10:8:59.68 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (80.100.155.83): login failed: RADIUS server is not responding in 21-Mar 10:8:59.68 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (12.205.149.63): login failed: RADIUS server is not responding in 21-Mar 10:8:59.68 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (72.228.28.111): login failed: RADIUS server is not responding in 21-Mar 10:8:59.68 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (81.71.11.31): login failed: RADIUS server is not responding in 21-Mar 10:8:59.68 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (24.42.116.223): login failed: RADIUS server is not responding in 21-Mar 10:8:59.68 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (166.82.173.96): login failed: RADIUS server is not responding in 21-Mar 10:8:59.68 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (71.12.188.249): login failed: RADIUS server is not responding in 21-Mar 10:8:59.68 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (65.190.85.108): login failed: RADIUS server is not responding in 21-Mar 10:8:59.68 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (216.250.59.138): login failed: RADIUS server is not responding in 21-Mar 10:8:59.68 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (217.83.52.142): login failed: RADIUS server is not responding in 21-Mar 10:8:59.68 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (81.68.234.174): login failed: RADIUS server is not responding in 21-Mar 10:8:59.68 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (213.219.75.38): login failed: RADIUS server is not responding in 21-Mar 10:8:59.68 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:8:59.71 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:8:59.78 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:8:59.78 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (166.82.153.143): login failed: RADIUS server is not responding in 21-Mar 10:8:59.78 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:8:59.78 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (69.208.87.150): login failed: RADIUS server is not responding in 21-Mar 10:8:59.78 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:8:59.82 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:8:59.82 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (67.159.22.234): trying to log in by mac in 21-Mar 10:8:59.84 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:8:59.84 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:8:59.89 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:8:59.90 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (217.121.26.51): trying to log in by mac in 21-Mar 10:8:59.90 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:8:59.90 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:8:59.95 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:8:59.96 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:9:0.1 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:9:0.1 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:9:0.6 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:0.6 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:0.7 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (69.148.185.28): login failed: RADIUS server is not responding in 21-Mar 10:9:0.7 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (172.143.76.117): login failed: RADIUS server is not responding in 21-Mar 10:9:0.7 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): internal error: login failed: failed to add queue: std failure: unknown next id (11) in 21-Mar 10:9:0.7 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:9:0.9 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:9:0.12 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:9:0.14 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:9:0.18 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (201.34.27.175): trying to log in by mac in 21-Mar 10:9:0.18 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:9:0.20 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:9:0.25 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (70.246.134.159): login failed: RADIUS server is not responding in 21-Mar 10:9:0.37 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:9:0.45 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:9:0.50 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (207.46.2.73): trying to log in by mac in 21-Mar 10:9:0.53 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (209.160.72.123): login failed: RADIUS server is not responding in 21-Mar 10:9:0.57 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:9:0.61 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:9:0.65 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:9:0.68 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:9:0.81 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:0.81 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:0.84 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:0.89 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:0.95 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:1.1 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:1.4 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:1.11 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (65.60.153.125): trying to log in by mac in 21-Mar 10:9:1.12 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:1.12 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:1.17 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (128.91.240.62): trying to log in by mac in 21-Mar 10:9:1.18 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (12.216.114.175): trying to log in by mac in 21-Mar 10:9:1.23 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:9:1.28 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:9:1.28 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:1.39 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:1.42 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:9:1.61 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:9:1.61 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:1.61 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (216.104.212.92): trying to log in by mac in 21-Mar 10:9:1.62 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:1.62 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:9:1.64 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:9:1.68 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:9:1.68 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:9:1.73 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:1.75 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 10:9:1.75 from xxx.xxx.126.82
hotspot,account,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 10:9:1.81 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:2.21 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:2.53 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:2.62 from xxx.xxx.126.82
hotspot,error,info,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 10:9:2.67 from xxx.xxx.126.82
hotspot,warning,debug XX.XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting request not sent: no response in 21-Mar 10:9:2.73 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (172.199.111.210): trying to log in by mac in 21-Mar 10:9:2.96 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (172.199.111.210): login failed: RADIUS server is not responding in 21-Mar 10:9:3.89 from xxx.xxx.126.82
hotspot,info,debug XX.XX:BF:82:0F:7A (68.35.73.41): trying to log in by mac in 21-Mar 10:9:4.90 from xxx.xxx.126.82
chris-oct
Tue Mar 21, 2006 9:05 pm
The saga continues
hotspot,info,debug XX:XX:BF:82:0F:7A (222.171.27.34): trying to log in by mac in 21-Mar 11:45:51.3 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:51.8 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:51.8 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.196): trying to log in by mac in 21-Mar 11:45:54.2 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:54.6 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:54.6 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (69.59.248.52): trying to log in by mac in 21-Mar 11:45:54.8 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (63.230.9.156): trying to log in by mac in 21-Mar 11:45:54.10 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:54.11 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:54.14 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:54.16 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:54.19 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.196): trying to log in by mac in 21-Mar 11:45:54.20 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:54.24 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:54.28 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (86.106.86.40): trying to log in by mac in 21-Mar 11:45:54.28 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (64.15.129.82): trying to log in by mac in 21-Mar 11:45:54.28 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (69.59.248.52): trying to log in by mac in 21-Mar 11:45:54.28 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:54.38 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:54.39 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:54.39 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:54.42 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.196): trying to log in by mac in 21-Mar 11:45:54.44 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:54.60 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:54.64 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (66.94.230.42): trying to log in by mac in 21-Mar 11:45:54.64 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (69.59.248.52): trying to log in by mac in 21-Mar 11:45:54.64 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:54.67 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:54.70 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:55.2 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (64.73.28.115): trying to log in by mac in 21-Mar 11:45:55.11 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.196): trying to log in by mac in 21-Mar 11:45:55.11 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (87.206.254.248): trying to log in by mac in 21-Mar 11:45:55.11 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:55.11 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:55.17 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (86.106.86.40): login failed: RADIUS server is not responding in 21-Mar 11:45:55.20 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:55.20 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:55.31 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:55.33 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:55.41 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:55.52 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (69.59.248.52): login failed: RADIUS server is not responding in 21-Mar 11:45:55.56 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:55.56 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:55.60 from xxx.xxx.126.82
hotspot,warning,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting request not sent: no response in 21-Mar 11:45:55.63 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:55.70 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:55.75 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:55.86 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:55.89 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:55.94 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:55.99 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (207.68.183.32): trying to log in by mac in 21-Mar 11:45:56.13 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.197.76): trying to log in by mac in 21-Mar 11:45:56.14 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:56.19 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:56.24 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:56.67 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:56.85 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:56.88 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:56.92 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.197.76): login failed: RADIUS server is not responding in 21-Mar 11:45:57.6 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (205.169.113.133): trying to log in by mac in 21-Mar 11:45:57.13 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:57.17 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:57.19 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:57.19 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.196): trying to log in by mac in 21-Mar 11:45:57.44 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (69.152.95.139): trying to log in by mac in 21-Mar 11:45:57.45 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:57.50 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:57.50 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (63.230.9.156): trying to log in by mac in 21-Mar 11:45:57.50 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:57.56 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:57.63 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:57.70 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:57.75 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (87.206.254.248): trying to log in by mac in 21-Mar 11:45:58.5 from xxx.xxx.199.22
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:58.11 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (65.202.88.4): trying to log in by mac in 21-Mar 11:45:58.38 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (68.48.6.34): trying to log in by mac in 21-Mar 11:45:58.38 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:58.41 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:58.45 from xxx.xxx.199.22
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:58.45 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:58.45 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:58.50 from xxx.xxx.199.22
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:58.53 from xxx.xxx.199.22
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:58.55 from xxx.xxx.199.22
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:58.63 from xxx.xxx.199.22
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:58.67 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.196): trying to log in by mac in 21-Mar 11:45:58.78 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (65.19.154.88): trying to log in by mac in 21-Mar 11:45:58.80 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (87.206.254.248): login failed: RADIUS server is not responding in 21-Mar 11:45:58.99 from xxx.xxx.199.22
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:59.34 from xxx.xxx.199.22
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:45:59.39 from xxx.xxx.199.22
hotspot,warning,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting request not sent: no response in 21-Mar 11:45:59.42 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.196): login failed: RADIUS server is not responding in 21-Mar 11:45:59.70 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (64.73.28.115): trying to log in by mac in 21-Mar 11:45:59.70 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:45:59.75 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:45:59.77 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (65.19.154.88): login failed: RADIUS server is not responding in 21-Mar 11:45:59.77 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (89.56.230.121): trying to log in by mac in 21-Mar 11:46:0.50 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:46:0.55 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:46:0.55 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:46:0.69 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:46:1.49 from xxx.xxx.126.82
hotspot,warning,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting request not sent: no response in 21-Mar 11:46:1.49 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (65.216.72.114): trying to log in by mac in 21-Mar 11:46:2.69 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (80.2.132.157): trying to log in by mac in 21-Mar 11:46:2.81 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:46:2.86 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:46:2.86 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (65.216.72.114): login failed: RADIUS server is not responding in 21-Mar 11:46:3.63 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:46:3.78 from xxx.xxx.126.82
hotspot,warning,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting request not sent: no response in 21-Mar 11:46:3.78 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (209.73.166.144): trying to log in by mac in 21-Mar 11:46:20.52 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:46:20.56 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:46:20.56 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (222.2.154.249): trying to log in by mac in 21-Mar 11:46:48.6 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (207.46.6.35): trying to log in by mac in 21-Mar 11:46:48.89 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:46:48.95 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:46:48.95 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (222.2.154.249): login failed: RADIUS server is not responding in 21-Mar 11:46:48.98 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (216.115.30.33): trying to log in by mac in 21-Mar 11:47:7.28 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (216.115.30.33): login failed: RADIUS server is not responding in 21-Mar 11:47:8.20 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (64.233.167.99): trying to log in by mac in 21-Mar 11:47:24.59 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:47:24.62 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:47:24.64 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (216.115.30.32): trying to log in by mac in 21-Mar 11:47:33.34 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (216.115.30.32): login failed: RADIUS server is not responding in 21-Mar 11:47:34.27 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (207.46.3.1): trying to log in by mac in 21-Mar 11:47:42.75 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:47:42.80 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:47:42.80 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (65.19.154.94): trying to log in by mac in 21-Mar 11:47:48.22 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:47:48.26 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:47:48.26 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (66.199.246.210): trying to log in by mac in 21-Mar 11:47:48.30 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:47:48.31 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:47:48.36 from xxx.xxx.199.22
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:47:49.20 from xxx.xxx.199.22
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:47:49.30 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (64.62.243.42): trying to log in by mac in 21-Mar 11:47:52.48 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:47:52.50 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:47:52.55 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (207.46.216.33): trying to log in by mac in 21-Mar 11:48:0.14 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:48:0.14 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:48:0.19 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (204.16.32.241): trying to log in by mac in 21-Mar 11:48:19.80 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:48:19.84 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:48:19.84 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (83.243.34.75): trying to log in by mac in 21-Mar 11:48:35.14 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:48:35.19 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:48:35.19 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (64.233.163.104): trying to log in by mac in 21-Mar 11:48:44.61 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:48:44.65 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:48:44.65 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (204.16.32.221): trying to log in by mac in 21-Mar 11:48:45.72 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:48:46.12 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:48:46.17 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (64.236.44.14): trying to log in by mac in 21-Mar 11:49:6.12 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:49:6.17 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:49:6.17 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (207.46.2.73): trying to log in by mac in 21-Mar 11:49:22.11 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:49:22.12 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:49:22.17 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (207.46.2.38): trying to log in by mac in 21-Mar 11:49:47.34 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:49:47.39 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:49:47.40 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (207.46.2.102): trying to log in by mac in 21-Mar 11:49:50.43 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:49:50.48 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:49:50.51 from xxx.xxx.126.82
system,info,account user admin logged in from xxx.xxx.197.76 via winbox in 21-Mar 11:50:0.64 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (207.46.2.70): trying to log in by mac in 21-Mar 11:50:0.68 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:50:0.68 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:50:0.75 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (207.46.2.63): trying to log in by mac in 21-Mar 11:50:7.15 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:50:7.20 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:50:7.22 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (207.46.2.59): trying to log in by mac in 21-Mar 11:50:21.6 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:50:21.11 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:50:21.11 from xxx.xxx.199.22
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:50:22.1 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (216.154.250.24): trying to log in by mac in 21-Mar 11:50:24.54 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:50:24.59 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:50:24.59 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (207.195.54.204): trying to log in by mac in 21-Mar 11:51:17.56 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:51:17.60 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:51:17.60 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (216.155.193.131): trying to log in by mac in 21-Mar 11:51:27.54 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:51:27.57 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:51:27.57 from xxx.xxx.199.22
system,info device changed by admin in 21-Mar 11:51:30.99 from xxx.xxx.126.82
system,info device changed by admin in 21-Mar 11:51:32.79 from xxx.xxx.126.82
hotspot,info,debug XX:XX:22:C2:D9:82 (169.254.10.162): trying to log in by mac in 21-Mar 11:51:37.40 from xxx.xxx.126.82
hotspot,info,debug XX:XX:22:C2:D9:82 (169.254.10.162): login failed: invalid username or password in 21-Mar 11:51:37.71 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (68.142.233.156): trying to log in by mac in 21-Mar 11:53:11.16 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:53:11.16 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:53:11.18 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (64.215.172.64): trying to log in by mac in 21-Mar 11:53:33.37 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:53:33.37 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:53:33.41 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (64.215.172.86): trying to log in by mac in 21-Mar 11:53:42.59 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:53:42.59 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:53:42.63 from xxx.xxx.126.82
hotspot,warning,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting request not sent: no response in 21-Mar 11:53:43.57 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (209.62.186.11): trying to log in by mac in 21-Mar 11:53:54.5 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:53:54.5 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:53:54.12 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (64.215.172.87): trying to log in by mac in 21-Mar 11:54:2.35 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:54:2.40 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:54:2.40 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (64.215.172.8): trying to log in by mac in 21-Mar 11:54:2.40 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:54:2.45 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:54:2.49 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (63.215.198.186): trying to log in by mac in 21-Mar 11:54:3.7 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:54:3.15 from xxx.xxx.126.82
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:54:3.15 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:54:3.32 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:54:3.45 from xxx.xxx.126.82
hotspot,warning,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting request not sent: no response in 21-Mar 11:54:4.7 from xxx.xxx.126.82
hotspot,error,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): RADIUS accounting stop request not sent: no response in 21-Mar 11:54:4.7 from xxx.xxx.126.82
hotspot,info,debug XX:XX:BF:82:0F:7A (64.215.172.24): trying to log in by mac in 21-Mar 11:54:7.85 from xxx.xxx.199.22
hotspot,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged out: host removed in 21-Mar 11:54:7.90 from xxx.xxx.199.22
hotspot,account,info,debug XX:XX:BF:82:0F:7A (xxx.xxx.181.51): logged in in 21-Mar 11:54:7.90 from xxx.xxx.199.22
chris-oct
How do we create supout file?
** Edit ** Ive just been shown how to do it. Right off the main menu in the winbox
tikkie
More on Host Changing
Wed Mar 22, 2006 9:23 am
Several posts ago I said this:
"Hi Normis:
At least the user stays logged in now but the constant detecting of a new host is still triggering many login attempts, huge amounts of log entries and hundreds of hits to our radius server. As a result I changed them over to local user auth so at least they don't use the bandwidth and bomb the radius server. "
Well, this is not going as well as we thought either. What I said above still apllies but another problem has surfaced. Let's say the dhcp device is happy and logged in. All is going well and then all of a sudden we get the dreaded message:
This is the same host that's already logged in and doing fine. Now a log message comes up and says:
So far so good. the hotspot limits the host from logging in again but....
DHCP ends up passing a new IP back to this perfectly good and logged in host. So now the host gets a new IP but he is not logged in again because of the limit of 1 login per host. He stays logged in with the old IP. So now we have.....
1. The host has a new DHCP entry with a new IP address that has been passed to it. Customer confirms his host IP has changed.
2. In the hostspot under hosts, the host is still listed but he has 2 entries now. One with the old and one with the new IP.
3. In the hotspot under active, the host is still listed but he is listed with his old IP.
So, by using "set addresses-per-mac=2 for hotspot server", when the perfectly good host is seen as a new host detected, his DHCP IP address changes even though he remains logged in. At this point his connection dies and he calls us. We then have to manually have him power down the host and we need to remove the DHCP entry, the active session and the 2 host entries before he powers back up and things start to work again until the whole thing repeats itself again.
Larry
theplanet
Re: Host ip keeps changing. Multiple logins.
Thu Sep 17, 2015 10:55 am
I have the same issue but there is no support i see... the forum is running only by users-customers of mikrotik? Where is the solutions? i have shown many complains about the same issue... but there is nowhere neither in wiki neither in forum(as much i have searched) any i say ANY solution... i have done all to solve this problem... anyone from MikroTik has any ideas how to solve it?
Users browsing this forum: Baidu [Spider], rilliam and 50 guests
