MUM Europe 2020
heiko_s
Sometimes slow bandwith test in ROS 5.22
Fri Jan 25, 2013 1:41 pm
we are running a small wireless network with clients authorosized over PPPOE and radius.
Not long ago we were able to test the speet to out AC with the bandwith tool correctly.
(e.g. a user has a limit of 2M, the bandwith test shows 2M with UDP)
But for a while now we get some strange results. Bandwith test shows arounf 36kBit on a 6M connection. If we restart the test, it sometimes raises to 6M as expected.
Testing real speed with uploading a file to the RB, speed seems to be normal (also if bandtwith test is currently showing 36kBit)
Has anyone noticed this behaviour and a solution for this?
Best regards from Germany
Heiko
samsung172
Re: Sometimes slow bandwith test in ROS 5.22
Sun Jan 27, 2013 4:56 pm
Have had this problms on RB1200 Boards. Fix was to change the port Connected. Try to change Ethernet port at Your NAS (pppoe-server) to se if it helps.
emersonpfs
Wed Jan 30, 2013 3:01 am
I have exactly the same problem...
Some solution?
Tks
heiko_s
Thu Jan 31, 2013 6:21 pm
We could not change the port because it is running on a bridge.
I noticed, that when i use another RB as destination, the behaviour stays the same. So i guess it has something to do with the queing on the AC because the connection (PPPOE-tunnel) is made between AC and CPE. Testing packets to an outside RB must pass the queues on the AC.
samsung172
Thu Jan 31, 2013 11:20 pm
should still be possible to change the port you are Connected into if using bridge.. You however need to have physical Access to the router.
Users browsing this forum: MSN [Bot] and 112 guests
