Ixo
Prevent accidental deletion.
Tue Jan 29, 2013 12:32 pm
Hi why there is no feature like that in Mikrotik? Just right click whatever, press 'Prevent accidental deletion' and then if you click by mistake on '-' you don't screw the whole network.
normis
Re: Prevent accidental deletion.
the feature is called "Safe Mode". Use that button more often
Ixo
Tue Jan 29, 2013 12:52 pm
Safe mode it's not what I am asking for. As far I concern 'Safe mode' is preventing from deleting anything. I want to only mark 1 or 2 things and have free will about the rest.
BTW: Safemode button? Where is this in Winbox?
normis
Tue Jan 29, 2013 12:53 pm
You want Windows approach, to ask every time "Are you sure you want to do this? Yes/No/Cancel"
Ixo
Tue Jan 29, 2013 12:59 pm
No I don't want windows yes/no...
You mark one thing with PAD, that think I don't know goes 'orange' or whatever ... and then when select it and press "-" or press "-" on webUI the option just stays there, nothing happens.
Edit: So to delete you need to first right click, deselect PAD and then delete it.
Found SafeMode button in winbox :D Was never looking up tbh.
normis
Tue Jan 29, 2013 1:02 pm
Accidental deletion can be undone with the "Undo" button in Winbox, or Undo command in console.
If you want to be protected against connection loss, use Safe Mode in addition to Undo command.
Ixo
Tue Jan 29, 2013 1:15 pm
OK, here is the example.
1. Log in to Winbox.
2. Go to Bridge.
3. Accidentally delete bridge.
4. Winbox will log you out straightaway.
5. If you are within the same network, you can login using MAC and press undo, otherwise take a helicopter and fly to the mountain 800m above the sea level.
6. Lets say u are on the same network, so you are able to get into that routerboard on MAC, you press Undo.
7. Bridge pops in.
7a. When I tried that, Mikrotik behaved very weirdly, I couldn't access most of things. Restarted winbox, and could not see that mikkrotik under 'browse', waited 5 mins and repowered this routerboard to finally get in (flying again?)
8. When I got in, Bridge was there, Ports were designated, however DHCP under bridge was RED.
Still think I ask for "undo" button?
normis
Tue Jan 29, 2013 2:31 pm
for the described situation, Safe Mode will save you.
1. Log in to Winbox and ENABLE SAFE MODE
2. Go to Bridge.
5. Safe mode detects missing connection, does "UNDO" command automatically
6. Winbox connection restored.
Ixo
Tue Jan 29, 2013 2:59 pm
This is what happens.
1. Logging in to Winbox.
2. Pressing "safe mode"
3. Accidentally deleting "bridge1"
4. Logs me out.
5. RouterOS loses IP address... so winbox shows 0.0.0.0
6. I take the helicopter :P
Never mind ... I see u take my feature request to be unnecessary, so let it be.
normis
Tue Jan 29, 2013 3:04 pm
Ixo that is not correct. Please try yourself. After winbox loses connection, wait some 10-20 seconds and everything will be automatically restored!
normis
Tue Jan 29, 2013 3:36 pm
We can also make something like this -
1. click any rule or item
2. click "lock" icon
3. removing of rule now impossible, shows "item locked"
4. click "unlock" to modify this item
Is anybody else interested in such functionality?
TrollMan
Tue Jan 29, 2013 3:45 pm
That would be great. I accidentally removed a VPN link and it took 30 minutes to get all red fw mangle, nat, dhcp and so on back . Thought I pressed comment but hit remove
ditonet
Forum Veteran
Forum Veteran
Tue Jan 29, 2013 3:51 pm
IMHO, if this 'lock' will also prevent accidental rule move and rule change, it will be nice and useful feature.
Regards,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
maximan
Trainer
Trainer
Tue Jan 29, 2013 6:38 pm
Nice +1
M
MKE Solutions > Professional Support IT (Spanish / English)
FastNetMon / FNM Manager: DDoS Detection Tools.
silviod24
Tue Jan 29, 2013 8:57 pm
Nice +1
M
I would like +1
Silvio
Lakis
Forum Veteran
Forum Veteran
Wed Jan 30, 2013 2:12 am
+ 1 billion for that I ask for this long time ago
cbrown
Trainer
Trainer
Wed Jan 30, 2013 2:55 am
Great idea. +1
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
JJX
Wed Jan 30, 2013 12:28 pm
Lock button would be nice :-)
We all press some button accidentally some times :(
chapex
Fri Feb 01, 2013 9:45 pm
I join the motion :lol:
+1
Ubnet datacenter: bandwith transport
karina
Fri Feb 01, 2013 11:00 pm
+1 here also, will be a life saver.
yogii
Sat Feb 02, 2013 5:47 pm
+1. how about post login winbox, all rules are locked? we have choose rules to unlocked first for edit. :D
matt
Sun Feb 03, 2013 4:14 am
What about an option for a system lock and or indervidual interfaces such as Virtual AP, WDS interface, VLAN, firewall rule, ip address, route etc etc etc?
Doing the wireless jobs that know one else wants to do.
InoX
Sun Feb 03, 2013 1:50 pm
why don't you all use Undo button after you delete something?
cbrown
Trainer
Trainer
Sun Feb 03, 2013 3:45 pm
That's not entirely my thought for it. I want to lock the rules so others know not to touch them and can't accidentally remove them.
So in these situations undo won't work. The way I work around this now is a very good backup system.
C.Brown
hel
Mon Feb 04, 2013 10:08 am
Lock entries deletion is absolutely useful.
danielillu
Mon Feb 04, 2013 10:13 pm
That would be perfect!
What I usually miss is the ability to absolutely lock interfaces from being disabled (typical error disabling the interface you are connected through), deleted (in case of bridge, vlan, tunnelings) or reconfigured.
Well... and could it be possible not to have the "Reset Configuration" available via GUI?
elgrandiegote
Tue Feb 05, 2013 5:14 pm
I would like +1
Diego
victorlu18
Thu Feb 21, 2013 2:59 pm
Interesting choice to spare more work because of an accident.
machack
Wed Feb 27, 2013 7:49 pm
That would be great. +1
Cesar Javier Robles
www.windnet.com.ar
MTCNA - MTCTCE - MTCRE - MTCWE
normis
Thu Feb 28, 2013 10:15 am
Regards,
you can't prevent other rules from being moved in front of this rule, causing it to be moved down/up
ronix
Thu Feb 28, 2013 10:40 am
very Interesting & helpful ...
ditonet
Forum Veteran
Forum Veteran
Thu Feb 28, 2013 11:24 am
That's true, but rule change prevention will be nice feature.
Regards,
slech
Long time Member
Long time Member
Thu Feb 28, 2013 1:57 pm
+1 !
sorry for my english
Users browsing this forum: censored224, eworm, Google [Bot], sindy, wifi442 and 81 guests
