omidh
Cisco VPN Client with Mikrotik as vpn server
Wed Jan 30, 2013 2:19 pm
Hi all.
Is it possible to configure Mikrotik as vpn server to work with Cisco VPN client?
or cisco vpn client use proprietary protocol that only works with Cisco devices?
if yes How?
omidh
Re: Cisco VPN Client with Mikrotik as vpn server
Sat Feb 02, 2013 10:17 am
is there anybody to help me on this?
onyx3821
Mon Mar 24, 2014 9:01 pm
I saw someone in another thread reply that this is impossible because Cisco (in their "Cisco way") uses vpnc instead of l2tp or pptp to make the connection, and Mikrotik doesn't support it. Since linux DOES, there was a way to do it in Metarouter, but that is faulty since after a reboot the bridge ports disappear.
Waiting for Mikrotik to figure out that this is actually the Cisco buster - if we could replace ASA's that are currently acting as VPN gateways, and have the client side never know the difference, that'd be awesome !
Rick
www.navitend.com
Thanks,
Rick Smith, Network Engineer
rsmith@navitend.com | www.navitend.com
P (973) 448 0070 | F (973) 448 0264
23 US Highway 206 Byram Twp. NJ 07874
carlosfrosario
Fri Feb 23, 2018 1:02 am
Managed to connect successfully to a cisco router as a vpnc client.
here's my config:
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=md5 enc-algorithms=des pfs-group=none
add auth-algorithms=md5 enc-algorithms=des lifetime=5m name=cisco pfs-group=none
/ip ipsec peer
add address=x.x.x.x auth-method=pre-shared-key-xauth dh-group=modp1024 dpd-interval=disable-dpd enc-algorithm=\
    aes-128,3des,des exchange-mode=aggressive generate-policy=port-override lifetime=5m local-address=y.y.y.y \
    mode-config=request-only my-id=key-id:{groupid} notrack-chain=prerouting secret={group passw} xauth-login={username} xauth-password=\
    {password}
/ip ipsec policy
add dst-address=0.0.0.0/0 level=unique proposal=cisco sa-dst-address=x.x.x.x sa-src-address=y.y.y.y \
    src-address=192.168.1.2/32 tunnel=yes
yiucsw
Fri Feb 01, 2019 9:33 am
are you use Metarouter? my CISCO Any connect need a VIP access key? will it pop up for input the dyamic key?
Users browsing this forum: Google Feedfetcher, krisjanisj, Znevna and 190 guests
