MUM Europe 2020
ali_hacker
Downgrade CCR1036-12G-4S to v 5.xx
Wed Jan 30, 2013 9:36 pm
Hello Everyone :)
i do appreciate if anyone have an idea about how to to downgrade router CCR1036-12G-4S from v6.xx to earlier v5.00 >>>if any one can suggest some sort of method i would be more than grateful.. 8)
EliteSystems
Re: Downgrade CCR1036-12G-4S to v 5.xx
Wed Jan 30, 2013 9:47 pm
Not possible.
honzam
Wed Jan 30, 2013 10:40 pm
Tille (CCR) is supported only in V6
LAN, FTTx, Wireless. ISP operator
ali_hacker
Wed Jan 30, 2013 10:57 pm
but it got to many bugs just like :
pppoe client get connected to router and you got near by the user dynamic but not running!!!!!!
and when i remove it and the user logged in again it get running dynamic !!!!!!!!
and also interfaces disappear then showed up !!!!is there is solve to that maybe i missed something?
and thank you so much for the quick replay
osvaldotcf
Mon Apr 01, 2013 4:41 pm
I have the same problem.
RB 1200 v6rc11
honzam
Mon Apr 01, 2013 7:58 pm
Do you use 6.0RC12? If not, upgrade your router. A lot of bugs is fixed http://download2.mikrotik.com/routeros/ ... .0rc12.npk
If you have rc12 and still problems then report to ---> support@mikrotik.com
Users browsing this forum: Google [Bot], ipfw, jweek, MSN [Bot], netnet, turnip, w32pamela and 133 guests
