ericsooter
PPPoE drops connections when Ethernet port bounces
Fri Feb 01, 2013 5:47 am
We have some RB750G and RB750UP's in the field acting as local PPPoE servers at the tower sites. Typically
we will bridge 3 ethernet ports together and put them in a pppoe-bridge (connecting 3 sector radios). Then we
will run the PPPoE server on the pppoe-bridge interface. When one of the ethernet connections in the pppoe-bridge
drops and reconnects; it drops all active PPPoE connections (even those on other ethernet ports). Is this normal
behavior? I haven't paid it much mind until we have had a recent problem with one of the ethernet interfaces at a
site that keeps resetting the PPPoE server every 5-10 minutes. Is there anything that can be done with settings to
mitigate this behavior? I've seen this behavior as recent as the 5.22 kernel.
Eric
heviejob
Re: PPPoE drops connections when Ethernet port bounces
Tue Feb 05, 2013 12:15 pm
I have the same issue but with a RB450G. I have bridged two ethernet ports and
I also run a PPPoE server on the bridge interface. Evertime one ethernet port gets
disconnected the all PPPoE sessions drop and reconnect. I have seen it on v5.22
and also on v 5.23. Am yet to figure out what might be causing this.
MrYan
Tue Feb 05, 2013 12:31 pm
Does setting the port to edge=yes-discover help?
Matt.
heviejob
Tue Feb 05, 2013 3:18 pm
Matt.
Where do I set that?
On the bridge or the ethernet ports.
MrYan
Thu Feb 07, 2013 12:14 pm
Matt.
Bridge.
farmermilosz
Wed May 01, 2013 12:16 am
Same problem by me.
I have 2xLAN and 2x WLAN interfaces bridged. PPPoE server is running on bridge interface.
When one of interfaces flaps - all sessions on all interfaces in this bridge are disconnected.
Setting edge=yes discover didn't help...
nickshore
Wed May 01, 2013 7:02 pm
Make sure that you have set an admin-mac on the bridge.
Nick.
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
Users browsing this forum: MSN [Bot] and 116 guests
