lrossouw
Prioritising under varying bandwidth
Fri Feb 08, 2013 7:46 pm
I want to create a queue setup. I am marking download type traffice using mangle in pre-routing. I want to ensure that this download traffic get lower priority than all other traffic. That way when I do other things the download traffic gets throttled back.
There are examples that show this but I was wondering if there was something for when bandwidth varies considerably. My internet bandwidth is not stable and varies quite a bit. I'm not sure how to just tell the router to drop download packets first.
dtoffo
Trainer
Trainer
Re: Prioritising under varying bandwidth
Sat Feb 16, 2013 1:31 am
you have to play with limit-at and max-limit: when every queue reached its limit-at, the remaining bandwith is distributed following priority and max-limit
max-limit can be higher than real bandwith, as routeros flushes queues proportionally: I suggest putting it at the teoric bandwith you should have from provider, that in real life I never reach (in Italy connections are ########).
lrossouw
Sat Feb 16, 2013 3:10 pm
Thanks.
Users browsing this forum: Bowen73, inteq, pukkita, Rahl, rezaf28, tomd, vecernik87, w0lt and 77 guests
