jp
Long time Member
Long time Member
minor HCI usability wishes
Thu Feb 23, 2006 5:52 pm
I would like the left sections in winbox to be in some sort of order. They aren't in any really. Maybe alphabetical. It would make use a little easier and quicker. Also I think a reorganizing of what's in system and what's in tools would be good. telnet is on one, mac-telnet is on the other, they are somewhat similar in purpose -why not in the same menu? Ssh client is more of a tool than a system setting. Thanks!
normis
Fri Feb 24, 2006 9:07 am
suggestions welcome. everyone - let's hear it :) !
kenk
Wed Mar 01, 2006 2:58 pm
The two things I'd like to see is the items with the longest dropdown window at the top of the list - for example depending on screen settings - you click on system and the list of system options is off the bottom of the screen - you mean theres ntp options somewhere at the bottom - and secondly to have the telnet function available from the root in a similar fashion to the simple ping. rather than in system. With routing
problems etc. the first thing I want to do having reach the next in the chain
Ken Kirkby
eflanery
Wed Mar 01, 2006 8:15 pm
Agreed, along with ssh.
/telnet w.x.y.z, is more natural then /sys tel w.x.y.z.
Could easily shave 1-2 grumbles per troubleshooting session, and save 5min explination time per tech.
--Eric
ICEASYCOM
Wed Mar 01, 2006 8:22 pm
I would like to split shutdown and reboot buttons by other. Sometimes we want quickly reboot the router, but we click not reboot, but whutdown button :)
dbostrom
Sat Mar 18, 2006 8:31 pm
Yeah, or maybe for shutdown a second "Are you REALLY sure you want to shut down your router that is an 80km round trip and hours of downtime away?" :D
Everytime I pull something from that area of the menu I cringe...
ghmorris
Sun Mar 19, 2006 1:48 am
Ditto.
I have shut down a router twice by accident.
Shutdown and Reboot have to be separated and a second dialogue box should ask for shutdown confirmation!!
George
djape
Sun Mar 19, 2006 2:04 am
Confirmation dialog box when disabling interface(s) in winbox.
I drink like a pirate and smoke like a hippie...
ldvaden
Sun Mar 19, 2006 5:54 am
A facility similar to that of IOS which allows piping CLI output through a filter.
e.g.,
/log print | grep -i extensive
or
/log print | incl extensive
rgds/ldv
mag
Sun Mar 19, 2006 10:52 am
you're right but it could be done already, e.g:
ssh admin@192.168.255.1 "/log print without-paging" | grep info
ldvaden
Tue Mar 21, 2006 1:06 am
Thanks for your post.
rgds/ldv
eflanery
Mon Mar 27, 2006 9:49 pm
Another minor interface issue...
It would be nice if Ctrl-D, in winbox terminals, were sent through to the process, rather than closing the window.
--Eric
jp
Long time Member
Long time Member
Fri Apr 28, 2006 4:55 pm
One more usability suggestion..
On most linux and many unix systems, administrative user (root) has a different prompt. What the prompt is, is of course based on the shell, not the OS.
As you see, regular users get a greater than prompt, root gets a number symbol.
jp@mexican:~> su -
Password:
Warning - All Access is logged.
Unauthorized access will be prosecuted.
mexican:~ #
[nobody@mis south] >
[admin@mis south] >
In MT, the administrative user gets the greater than prompt, just like the less privelaged user. It would nice if the prompt differed for the types of user, just like in linux shells.
butche
Trainer
Trainer
Fri Apr 28, 2006 6:55 pm
For me, I'd like to be able to make the winbox window smaller. Right now, you can't make it any smaller than the list of buttons on the menu. If I need to see 2 or 3 winbox screens at once, it is difficult because I cannot make them fit.
Also, I'd like a button at the top that would arrange all open windows. You can do it by "tiling" the windows (all would be fitted to current winbox area), or "cascading" (that's the windows word for it).
Butch Evans
Mikrotik Certified Trainer
Mikrotik Certified Consultant
BLOG: blog.butchevans.com
http://store.wispgear.net/
butche
Trainer
Trainer
Fri Apr 28, 2006 6:57 pm
This is not very clearly stated. The "windows" I'd like to be able to "tile" or "cascade" are the open applets in the winbox.
Butch Evans
jp
Long time Member
Long time Member
Fri May 12, 2006 8:16 pm
with regard to software packaging to make it more userfriendly...
Just plain routerboard package I presume is rb230, whereas the routeros-rb500 is for 5xx/1xx routerboards. Perhaps routerboard-xxx.npk should be renamed routeros-rb230-xxx.npk to be properly descriptive. If there were a way to make the naming include the rb1xx for the 5xx package that would be helpful too.
Eugene
Forum Veteran
Forum Veteran
Fri May 12, 2006 8:48 pm
"plain" package fits also regular x86 equipment.
Tout individu a droit à la vie, à la liberté et à la sûreté de sa personne.
normis
Mon May 15, 2006 9:23 am
routeros-x86 is for all X86 (PC like) devices, including RB230.
routeros-rb500 is for MIPS processor routerboard devices
jp
Long time Member
Long time Member
Mon May 15, 2006 6:59 pm
While we're at it, in Winbox, it would be nice if there were a scale on the traffic graphs.
If you want to know what the bandwidth peaks are, you have to compare it to the most recent traffic, estimate or calculate a factor, multiply it by the current bandwidth, which had probably changed by the time you did the math. If there were a scale, even a changing scale, it would be much easier to see a traffic spike and follow the horizontal rule to the a y-axis scale. Time scale on the X-axis would be good too.
I use mrtg for long term traffic graphing, but the traffic graphs like above are very nice for more detailed analysis.
normis
Tue May 16, 2006 9:21 am
... or you could do a mouse-click on the graph and have your scale ...
sten
Forum Veteran
Forum Veteran
Thu May 25, 2006 5:05 am
Here are some suggestions;
* put back neighbor discovery on bridge members. it's -really- annoying
when you try to find out which interface those discovery packets came
in on.
* remove 'shutdown' from winbox but keep it in terminal.
- How often do you do it anyway?
* packets/second graphs!
- perhaps as a transparent overlay for bytes/second?
* macros or functions in script context
* ability to do "monitor do={" without them automatically being assumed to "once"
* better error handling in scripts.
- line and character hint when / importing would be nice
* packet/second trigger for traffic-monitor.
- how many tiny packets can you send at the rate of 2 mbit / sec ?
* ability to select connection-tracking pr rule
* ability to run a / interface pppoe-server server monitor in loop
which triggers every time someone logs in or out
* more informative log messages for ppp(oe)
* error and informational statistics on ethernet and wlan interface
routeros probably gets blamed for alot of faulty wiring, which is
easily debugged using statistics.
* wireless beacon interval setting
- 10 times a second is wasteful for fixed wireless.
- doubling the rate because you add a virtual ap is twice so.
* ability to set mtu to higher than 1500 and let kernel decide wether it's possible or not. it's possible for several common 10/100 mbit cards.
* ability to do
- "/ tool graphing queue find"
- "/ tool graphing interface find"
- "/ tool graphing resource find"
* ability to adjust max resulting eoip packet size to deal with smaller mtus
* stop setting df flag on non-tcp packets (it's breaking standards and functionality.)
Move along. Nothing to see here.
jp
Long time Member
Long time Member
Thu Jun 08, 2006 6:56 pm
There seem to be print options that don't work. This is with 2.9.25
[admin@knoxcourthouse] ip firewall mangle> print stats
invalid value for argument filter
[admin@knoxcourthouse] ip firewall mangle> print detail
[admin@knoxcourthouse] ip firewall mangle> print ?
print values of item properties in different formats.
<filter> --
without-paging --
count-only --
interval --
append --
file --
chain -- Chains through which packets are traversing
action -- Action to undertake if the packet matches the rule
jump-target -- Name of the target chain, if the action=jump is used
address-list -- Address list in which marked address put
new-packet-mark -- Specify the new value of the packet mark to be used in conjunction with action=mark-packet
new-connection-mark -- Specify the new value of the connection mark to be used in conjunction with action=mark-connection
new-routing-mark -- Specify the new value of the routing mark used in conjunction with action=mark-routing
new-tos -- Specify TOS value to be used in conjunction with action=change-tos
from -- item numbers
stats --
value-list --
terse --
detail --
Also in winbox, in many different parts of winbox, I noticed a little disabled text at the bottom of the window. I had to disable and renable something to figure out what it meant. Greyed out disabled means enabled - sort of a double negative, which is rarely helpful. It would be better to either only show disabled text when it's disabled, or enabled instead of disabled.
Either way it's redundant, since a disable action button appears when the item is enabled, and vice versa for an an enable button.
eflanery
Thu Jun 08, 2006 7:09 pm
Under 2.9, print works a bit differently under much of the '/ip firewall' hierarchy.
/ip firewall filter print all detail
works, while:
/ip firewall filter print detail
does not.
--Eric
ktw-matt
Wed Nov 08, 2006 7:33 pm
I have a great idea for the shutdown and reboot buttons in winbox.
Instead of its current format:
Do you want to shutdown?
[Yes] [No]
Do something like this:
Do you want to SHUTDOWN?
( ) yes
(*) no
[Continue]
Where 'yes' and 'no' are radio buttons, and no is selected by default.
This way, the function they're working with is in all caps (just so it stands out) and then if the user accidently clicks the button or presses enter, the action is set to 'no' by default.
normis
Thu Nov 09, 2006 8:50 am
there is no way to battle with human nature when it comes to being careful. there is a line when improving security measures starts killing usability. what i'm saying is - it won't help anyone.
ktw-matt
Thu Nov 09, 2006 6:45 pm
normis, I understand where you're coming from, but.. there's a big difference between typing out the shutdown command and clicking a button in a GUI. Adding a bit of security to the GUI, such as this, could not hurt, could it?
However, I guess I could see someone quickly selecting 'yes' and clicking 'continue'. But surely not, if the function name stood out (ie, "SHUTDOWN").
Any thoughts?
janisk
Fri Nov 10, 2006 2:58 pm
maybe when askiking if you realy want to shut down and answers are - YES|NO set to SHUTDOWN|NO
or even make it changable so person can set to "CLIMB 100M tower to startit"|no
and if person sets this feature to NO|NO he actualy cannot shutdown this router
EDIT:
actauly there is even better and safer idea - if you want to reset or shutdown router - you have to enter password to do that, that ways - those FAST WRITERS that cannot read will be forced to stop, atleast they should stop. i hope. :roll:
GotNet
Wed Jan 03, 2007 4:31 am
Winbox loader wishes:
* In the search button - If an IP is displayed and selected, let the IP transfer to the "Connect To:" box instead of the MAC.
* Remember "Load Previous Session" de-selection. Won't stay off!
* Changelog for WinBox.
* Changelog for WinBox. Or at least a note somewhere that the version has changed.
Users browsing this forum: al3xeezer, bigquestion, Bing [Bot], buscfonia, Google [Bot], wyre and 116 guests
